Sand blaster |
Sand blaster |
Harpo |
May 9 2013, 04:41 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Where can I pick up a good sandblaster? Any experience with Harbor freight or Eastwoods?
Thanks David |
gms |
May 9 2013, 05:16 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Harpo |
May 9 2013, 06:30 PM
No I'm looking for a 100 lb sand blast unit. I want to do some sand blasting on my car.
Thanks David |
VaccaRabite |
May 9 2013, 06:52 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The Eastwoods and HF units are the same units.
I bought on of the HF units and it worked for 5 minutes before part of the tank blew apart. Zach |
okieflyr |
May 9 2013, 07:34 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I've been using a HF unit and it works "ok". These are very sensitive to any moisture (you'll need good cooling and line dryer) in the line from the compressor and will start to make the media clump and clog inside the tank. As the moisture builds I have to shake the tank to get dry media to feed into the petcock for resumed operation.
cary |
May 9 2013, 08:51 PM
Take a look at TP Tools.
Cap'n Krusty |
May 9 2013, 10:27 PM
I'd think LONG and HARD before attempting to sandblast a car. Positives: Takes paint off. Negatives: Warps sheet metal, sand gets into places from which you never seem to be able to get it out, makes a huge mess. Maybe more, but I'm tired and can't think of anything right now.
The Cap'n |
jimkelly |
May 10 2013, 05:25 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
Eric_Shea |
May 10 2013, 09:28 AM
If it's an entire car. Pay someone. It will be cheaper than the unit and the new compressor you'll need to run it properly.
McMark |
May 10 2013, 09:33 AM
QUOTE If it's an entire car. Pay someone. It will be cheaper than the unit and the new compressor you'll need to run it properly. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 05:34 PM |
