Harpo
May 9 2013, 04:41 PM
Where can I pick up a good sandblaster? Any experience with Harbor freight or Eastwoods?
Thanks
David
QUOTE(Harpo @ May 9 2013, 05:41 PM)
Thanks
David
If you are referring to the cabinet it is a good deal, if you are asking about the gun...it is cheap and work OK
Harpo
May 9 2013, 06:30 PM
No I'm looking for a 100 lb sand blast unit. I want to do some sand blasting on my car.
Thanks
David
VaccaRabite
May 9 2013, 06:52 PM
The Eastwoods and HF units are the same units.
I bought on of the HF units and it worked for 5 minutes before part of the tank blew apart.
Zach
okieflyr
May 9 2013, 07:34 PM
I've been using a HF unit and it works "ok". These are very sensitive to any moisture (you'll need good cooling and line dryer) in the line from the compressor and will start to make the media clump and clog inside the tank. As the moisture builds I have to shake the tank to get dry media to feed into the petcock for resumed operation.
cary
May 9 2013, 08:51 PM
Take a look at TP Tools.
Cap'n Krusty
May 9 2013, 10:27 PM
I'd think LONG and HARD before attempting to sandblast a car. Positives: Takes paint off. Negatives: Warps sheet metal, sand gets into places from which you never seem to be able to get it out, makes a huge mess. Maybe more, but I'm tired and can't think of anything right now.
The Cap'n
jimkelly
May 10 2013, 05:25 AM
Eric_Shea
May 10 2013, 09:28 AM
If it's an entire car. Pay someone. It will be cheaper than the unit and the new compressor you'll need to run it properly.
McMark
May 10 2013, 09:33 AM
