Gasket Sealer for EFI Components, Is it really necessary..? |
Nozzle |
May 10 2013, 01:09 PM
Member Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
I'm in the process checking the stock D-jet system for leaks to solve an uneven idle problem. Well from the looks of it I'm not the first owner/mechanic to deal with this issue on the car as every gasket I've come across is slathered on both sides with some kind of orange gasket sealer.
My question is should I be reapplying this gasket sealer with the new gaskets I'm using? Thanks, John |
McMark |
May 10 2013, 09:30 PM
Absolutely not.
VaccaRabite |
May 10 2013, 09:34 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Make sure you clean ALL the old sealer off or it will never fully seal.
Zach |
Nozzle |
May 11 2013, 08:04 AM
Thanks for the replies guys. I thought the answer was no but wanted to make sure. (IMG:style_emoticons/default/smile.gif)
JeffBowlsby |
May 11 2013, 08:09 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Using the orange silicone is not recommended.
The vacuum hoses are 1mm undersize of their nipple and will shrink/conform to the nipple to be airtight, to the point they are hard to get off. Unless they are old or have been loosened many times, when they become not airtight and then need to be replaced. I have used a thin film of sealant on the interface of old hoses to their nipples in a pinch, but old hoses really need to be replaced for them to function as they were designed. I have also experienced leaks at the intake runners to head interface and use the spray on copper gasket on both surfaces, it works well and gets them airtight first time and permanently. Bontempi does this too...who I give credit to for the idea. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:09 AM |
