Wire Help!, Where does it go? |
914Bryan |
May 10 2013, 01:53 PM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
Any idea where this broken wire goes? It is a white wire that appears to attach to the coil. If so, is it on the + or - side?
Obviously I will repair and re-connect once I find out where to put it.... Maybe this may be part of my poor running engine problem??? |
JeffBowlsby |
May 10 2013, 01:55 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Year of car? Engine size? Which harness does this come out of? It almost looks like the thermoswitch wire, connects to the sensor on the air plenum bracket just above the case.
SLITS |
More than likely it is the power to the AAR. It will connect to a red wire from the AAR.
Turn the key on and see if you have constant 12 VDC at the connector. If so, that's what it is. If not, it is what Jeff said. |
914Bryan |
May 10 2013, 02:09 PM
Sorry, '74 2.0 Djet. Loom connects to the side of the distributor at the vaccum advance, and then dissapears under the throttle body plate. Cant see where it goes from there.
SLITS |
May 10 2013, 03:34 PM
If it were the AAR feed it would be part of the engine harness ... 12 pin connector at the relay board.
If it were the thermotime switch it would be part of the FI harness - 4 pin white connector at the relay board. |
914Bryan |
May 10 2013, 05:23 PM
I think the wire was for the thermoswitch sensor. I found it nearby with no wire attached. Everything else was hooked up that I could tell.
I have no idea what a thermoswitch is or what it does, but I spliced a new wire in and connected it. If anyone could explain what it is for, that would be great! Thanks for the help! Bryan |
type47 |
May 10 2013, 07:10 PM
I have no idea what a thermoswitch is or what it does, ...If anyone could explain what it is for, that would be great! I just looked in the workshop manual and a thermoswitch is present in both D-Jet and L-Jet FI systems and controls the cold start injector. When cold enough (many 914'ers in warm climates post that they don't have CSV (injector) or Thermoswitch) it causes the cold start injector to inject extra fuel to assist in running until engine warms up (there is a thermotime switch in there also)... |
Lo-Fi Version | Time is now: 20th May 2024 - 11:57 PM |
