Wiring Diagram for 100W headlight relay install? |
SKL1 |
May 12 2013, 07:27 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Putting in the 100W hi beam H4's and need the wiring diagram to install the relay(s) so the 40 year old wiring system can handle it.
Can't find it anywhere and search wasn't helpful... TIA. |
VaccaRabite |
May 12 2013, 07:32 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Get relays from FLAPS and the diagram is on the box. Makes it really easy.
If you are running big lights like that I'd make the power run all the way back to the battery (remember to keep it fused). |
Mike Bellis |
May 12 2013, 09:32 PM
May 12 2013, 09:41 PM
If you are running big lights like that I'd make the power run all the way back to the battery (remember to keep it fused). (IMG:style_emoticons/default/agree.gif) I'm not sure the stock wires can handle the 100W in the long run. (IMG:style_emoticons/default/idea.gif) |
Cap'n Krusty |
May 12 2013, 10:33 PM
If you are running big lights like that I'd make the power run all the way back to the battery (remember to keep it fused). (IMG:style_emoticons/default/agree.gif) I'm not sure the stock wires can handle the 100W in the long run. (IMG:style_emoticons/default/idea.gif) That's why you run relays. Big wires from the battery to the relays, big wire from the relays to the bulbs, big ground wires. The stock wiring is used to activate the relays. We do this all the time in Audis in order to save the combi switches, even with stock bulbs. The Cap'n |
May 12 2013, 10:56 PM
If you are running big lights like that I'd make the power run all the way back to the battery (remember to keep it fused). (IMG:style_emoticons/default/agree.gif) I'm not sure the stock wires can handle the 100W in the long run. (IMG:style_emoticons/default/idea.gif) That's why you run relays. Big wires from the battery to the relays, big wire from the relays to the bulbs, big ground wires. The stock wiring is used to activate the relays. We do this all the time in Audis in order to save the combi switches, even with stock bulbs. The Cap'n I know. That's why i agreed with Zach's post who basically said the same thing ... (IMG:style_emoticons/default/biggrin.gif) |
SKL1 |
May 13 2013, 05:47 AM
I may be an idiot, but what is FLAPS?? I see it all the time and don't know what it stands for...
Rleog |
May 13 2013, 06:14 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
jim_hoyland |
May 13 2013, 07:10 AM
Get that VIN ? Group: Members Posts: 9,300 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What size wires should be used:
Battery to relay Relay to light(s) Min Amperage of relay |
0396 |
May 13 2013, 07:29 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
orthobiz |
Sep 3 2013, 04:55 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I don't see wire gauge size in the "Relay Book" linked in one of the responses.
Paul |
Sep 3 2013, 04:59 PM
Volts * Amps = Watts
12 V * ?Amps = 100 Watts OR ? Amps =100W/12V OR 8.33 Amps = 100W/12V Use a 10Amp fuse inline and you can get by with 16Ga wire. Read the AMP draw on the device you will be using. It will be on the package somewhere. rich |
Sep 3 2013, 05:09 PM
Oh,
Only use the stock wiring for the trigger on the relay. The stock light switch is already over stressed, it will melt, and they are NLA anywhere. ITs a pain, but run new wires up through the tunnel, into the interior, up over the steering column (zipties) and through the main grommet into the front trunk to power those lights. Rich |
orthobiz |
Sep 3 2013, 06:24 PM
Thanks.
Paul |
jim_hoyland |
Sep 3 2013, 07:01 PM
Will one relay power low beams and high beams ? Or, are two relays needed ?
Mike Bellis |
Sep 3 2013, 08:59 PM
Sep 3 2013, 09:02 PM
It's two different circuits, so two relays are required.
One larger wire for dedicated power to a common jumpered pole to supply power for both is ok, you don't use both circuits at the same time. Rich |
JeffBowlsby |
Sep 3 2013, 10:41 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is the wiring diagram for the high/low beams + ground headlight circuits.
As a place to start for design purposes, consider the factory main power wire off the headlight switch to the fuses as 14 AWG, from the fuses to each headlight and ground wires are 16 AWG. As I recall the wiring is not as much of an issue as the ehadlight switch in terms of ampacity. Hopefully someone will figure out the new circuitry configuration and relay configuration, wire gages required for specific lamp sizes, and post it. The headlights are L1/L2. Attached thumbnail(s) |
jim_hoyland |
Sep 4 2013, 09:31 AM
See: http://www.rowand.net/Shop/Tech/WiringHeadlightRelays.htm
Most of your questions are answered plus there is a neat wiring diagram. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:29 PM |
