Rubber parts, Where are they found? |
newdeal2 |
Nov 26 2004, 07:41 AM
Unregistered |
Who stocks the rubber "grommets" for the 914. I need the ones for the piping thru the tins, the drains etc.
Rhodes71/914 |
Nov 26 2004, 07:53 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
hargray2 |
Nov 26 2004, 11:20 PM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
Most any hardware store. They are usually in drawers near the specialty fasteners.
SGB |
Nov 27 2004, 12:04 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I failed at the hardware store but the FLAPS (autozone in this case) had a bunch of different sized really big grommets actually for PVC valves that I managed to mach up pretty close to the holes for battery cable and alternator harness. O still haven't figured out what to do for the Jpipes. They gotta get really hot I think...
914werke |
Nov 27 2004, 01:43 AM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive asked this before but never got much (any) of a reply.
Has anyone had any experiance w/the "Complete" rubber kits offered by Tweeks and the like? These are the ones that cost a bazillion dollars but claim to have "Every" rubber part on the car included. There are two versions one OE and one repro for 3-4 hun. less. For someone doing a ground up or a concours restoration it mighyt be worth it but ..every? (IMG:style_emoticons/default/unsure.gif) |
maf914 |
Nov 27 2004, 07:20 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
QUOTE(newdeal2 @ Nov 26 2004, 05:41 AM) Who stocks the rubber "grommets" for the 914. I need the ones for the piping thru the tins, the drains etc. A lot of the rubber grommets and rubber boots for the T4 engine tin can be bought through VW dealers. I used the 914 Pet parts list to record all of the part numbers and names for these that I could figure out and then went to the local dealer. I lucked out and found a helpfull parts tech who took the time to look up all of the numbers and order them for me. The T4 was used in many VW's and buses. Unfortunately there are some differences between all of the applications. The parts numbers for the 914 pieces are all VW numbers. I was not able to find the numbers for the grommets in the rear vertical sheet metal panel, but my originals were still usable for those. I was able to replace the grommets and boots in the left, right and front sheet metal pieces, including the heater tube grommets and the oil pressure sensor boot. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:19 PM |
