Most useful garage/shop equipment, What is the best/fun/useful shop equipment? |
struckn |
May 14 2013, 07:48 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Really, those are a given.
I think he is asking what ELSE you might consider as mandatory. Rich [/quote] A surround sound, multi speaker, FM Radio with CD 8 disc changer and a fridge. Keeps you working all day and happy to be there. Also a shop Dog for company. (IMG:style_emoticons/default/piratenanner.gif) |
scrz914 |
May 14 2013, 07:58 PM
Member Group: Members Posts: 397 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
I'll second the Dremel. It's a small item but indispensable.
The other thing would be strong ramps. It's much easier to raise the front or rear end than having to jack the car up. I've found a small media blasting cabinet to be very handy for restoring old parts. |
moparrob |
May 14 2013, 09:08 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
A portable bead blaster, definitely!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1368587313.1.jpg) |
FourBlades |
May 14 2013, 10:38 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
9 volt lithium ion 1/4 inch impact driver.
It is small, weighs very little, and is great for spinning nuts and bolts on and off quickly. With a quick change chuck you can pop in small drill bits, screw driver bits, and sockets in a second. It is a big time saver over using a racheting wrench. I keep a torque wrench handy for when it comes time to tighten something for good. John |
PanelBilly |
May 14 2013, 10:55 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Computer with plastic over the keyboard
euro911 |
May 15 2013, 12:08 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Time (IMG:style_emoticons/default/dry.gif)
scotty |
May 15 2013, 07:28 AM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
An extra 100 square feet to store it all.
Mark Henry |
May 15 2013, 08:11 AM
An extra 100 square feet to store it all. Only 100sq/ft (IMG:style_emoticons/default/lol-2.gif) I built a a big shop (about 1800sq/ft) when I got done I went, "Fuch...I didn't build it big enough!" Then I built an attached 2 car garage on the house, as I was building I added 8 extra feet on the planned length, when I got it done I went, "Fuch...I didn't build it big enough!" (IMG:style_emoticons/default/rolleyes.gif) |
scotty |
May 15 2013, 08:24 AM
Too much is never enough! (IMG:style_emoticons/default/beer.gif)
shuie |
May 15 2013, 08:25 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Most useful:
Good workbench and vise. Maybe the air compressor. A lift would be awesome. Most fun: 10 gallon 240V electric brewery (IMG:http://www.914world.com/bbs2/uploads_offsite/i36.photobucket.com-2075-1368627921.1.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-2075-1368627921.2.jpg) |
wobbletop |
May 15 2013, 08:57 AM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
Lift, yes... but which... 4 post, 2 post, scissor?
worn |
May 15 2013, 09:24 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I have done some brief searching and have seen a few cool posts, but I would like to get things together in one place. What is your favorite/most useful shop equipment? I'm moving soon and it is going to be a good opportunity to think about what sorts of equipment it would be fun to have on hand! I'll start off with: A good heavy duty work bench A dual valve low profile aluminum jack Wall mounted rack for holding wheels/tires Wishlist: media tumbler (for cleaning small parts) do-it-yourself plating equipment 12 ton press bench grinder air compressor I think it would help if we knew if this is the space you will be using. It won't hold a lot and still allow you to park two cars. Sorry, but tools scratch paint and snag purses. See Wayne's World. Also what kind of work do you plan. I have pretty scruffy cars so I do grinding and sanding and stuff. For that a compressor a mig and lots of cheap air tools. For a mechanic, a bench and tool storage would probably come out ahead. For me this has turned from slippery slope to full blown free fall - I am a tool junkie, and there's no denying it. Yeah, I can quit any time I want... |
BK911 |
May 15 2013, 10:01 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Picked up one of these for $80 with 20% coupon a few years ago.
Have no idea how I lived without it for so long!! On sale now: http://www.harborfreight.com/580-lb-capaci...ifQ%3D%3D%0D%0A In addition to some of the other items, include a wire wheel attachment on bench grinder. Makes rusty bolts look new! |
blackmoon |
May 15 2013, 10:54 AM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
This one is obvious. Any decent home auto shop should have the following: 1. atomic hydrogen welder 2. induction plasma spheroidisation processor 3. high pressure gamma ray reactor (don't worry, you only need 250mg of antimatter) 4. martian sundial (particularly helpful if you live on the Martian equator) 5. an orange tabby cat named Steve for company I mean, that's what I would guess. and a towel |
Mark Henry |
May 15 2013, 11:01 AM
Lift, yes... but which... 4 post, 2 post, scissor? IMHO I find the 2 post is the best for service, scissor is fine for 914, 911, bugs, etc., as there's nothing to work on in the centre of the car. To me the 4 post is more geared towards storage, where you don't want to leave the suspension unloaded. Downside of any lift is overhead clearance. We could have used that lift during the first tranny clinic...right Walter (IMG:style_emoticons/default/wink.gif) |
rnellums |
May 15 2013, 11:15 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
The question was really posed more in general. The garage space pictured in the original post is where i am now, now where I am moving to, but it is certainly smaller than the ideal garage size (can a garage be too large?). I'm loving the suggestions so far though.
Lo-Fi Version | Time is now: 1st June 2024 - 09:03 PM |
