DISTRIBUTOR QUESTION, What do I have |
72914S |
Nov 26 2004, 09:17 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Dumb Question #914 ... (There have been others)
I see all the talk about 009 & 050 distributor, what is the stock distributor in a `73 2.0 ? (IMG:style_emoticons/default/wacko.gif) |
jwalters |
Nov 26 2004, 09:21 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
the advance curve
jwalters |
Nov 26 2004, 09:28 PM
oh yea--if there is a vacuum can on it---it is NOT a 009 model most likely an 050--
Nov 26 2004, 10:42 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The stock distributor on a 914 would be one of the "205" family of distributors. The 1.7 (and 2.0) with D-jetronic fuel injection would have a second set of "trigger points" in the bottom of the distributor, with a three-wire plug down at the front part of the distributor. Only a few D-jet-specific distributors will acutally work the D-jet system (without real electronic heroics), so if you have working D-jet EFI you have a stock distributor or close enough.
The 1.8 914s used L-jetronic EFI (in the US at least!) and had a version of the 205 distributor with the vacuum gizmo ("dashpot"), but without the FI trigger points. The 050 and 009 are centrifugal-only distributors that are used in some carb conversions. They have no vacuum cannister. --DD |
72914S |
Nov 27 2004, 06:37 AM
Thanks guys. I`m thinking of installing an Crane electronic ignition system and was confused as to which model I needed. They only talk about the 009 or the 050,so now I`m still confused
Lo-Fi Version | Time is now: 5th May 2024 - 10:33 AM |
