MSCD boxes for 2056 type Carbed engines, Where are you locating them. Engine bay picture requested of ign. |
wndsnd |
May 19 2013, 07:10 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Starting to set up the bay and I was wondering where the best spot is
to be mounting the MS-AL. Can anyone send me pictures of box and coil placement? Thanks John |
rhodyguy |
May 21 2013, 12:40 PM
something like this? i mounted the box a bit too high. it makes bolts a tight squeeze and the lid r&r a pain. i open ended the bolt holes on the arms and i only have to loosen the bolts a bit and the arms slide out.
k Attached thumbnail(s) |
yeahmag |
May 21 2013, 02:58 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Mines on the firewall, but in the rear trunk.
ThePaintedMan |
May 21 2013, 03:17 PM
Mines on the firewall, but in the rear trunk. Aaron, I've been thinking of mounting mine there. But how did you do it? I'm using the vibration mounts, so I wouldn't be able to get to the other side of the rubber "stud" to put the nut on it. Did you just use self-tapping screws? |
yeahmag |
May 21 2013, 03:18 PM
Rivnuts! I'm a huge fan of them!
Jeffs9146 |
May 21 2013, 03:31 PM
QUOTE Starting to set up the bay and I was wonderingwhere the best spot is To be mounting th e MS-AL. Can anyone send me pictures of box and coil placement. I mounted mine using the 914-6 CD box mount that AA sells! It is number 2 shown here Auto Atlanta CD mount plate Attached image(s) |
7275914911 |
May 21 2013, 03:32 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
wndsnd |
May 21 2013, 03:43 PM
How about pictures of carbed engines, so I can see what space I am working with.
I like the ideas so far but I was thinking of going on the firewall on the left side. I saw a car today and it looks like the carbs sit back a bit..... |
yeahmag |
May 21 2013, 03:51 PM
wndsnd |
May 21 2013, 03:55 PM
Aaron, thats what I am going to run, the Mallory 6AL. It is kind of big so thus my concerns.
Great shot! |
ThePaintedMan |
May 21 2013, 07:00 PM
Sorry for jumping on your thread wndsnd, but you're right - that's a great installation spot Aaron.
I know what Rivnuts are but I'm a little unfamiliar with how they install. Do I need to buy the special puller? If so I doubt I'm going to go that route for just 4 rubber studs (IMG:style_emoticons/default/biggrin.gif) Either way, very cool! The beer is even better! (IMG:style_emoticons/default/beer3.gif) |
yeahmag |
May 21 2013, 07:19 PM
Technically you need an installer, but I've DIY'ed it with an allen bolt, nut, and assortment of washers before. All you need to do is crush the aluminum portion by tightening it. There is also a fairly cheap rivnut tool out there that lasts a while before self destructing. If you don't mind 1/4-20 the Harbor Freight installer is OK.
Jerry75914 |
May 21 2013, 07:29 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
wndsnd |
May 21 2013, 10:23 PM
Nice looking bay. Did you grind off the feet of the Optima to get it to fit in the tray?
No hijack here George. We are all just swapping ideas. |
Jeffs9146 |
May 22 2013, 12:14 AM
rhodyguy |
May 22 2013, 09:53 AM
if you look at my optima and jerry's, note the non-stock clamp. it's the one that used to be avail thru optima before johnson controls took over. no grinding required with them at all.
k |
JamesM |
May 22 2013, 10:24 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
That is exactly where I stuck my Mallory 6-AL. Great minds must think alike. I did it to keep the engine bay looking closer to stock and because its already pretty cramped with all the FI stuff. If you are running carbs though you have a bit more space to work with, I think that extra bracket where the ECU normally mounts would be a good way to go as well. |
Jerry75914 |
May 22 2013, 12:27 PM
thanks! i didn't grind anything off of the battery, but I did trim off the lip on the battery tray on the side closest to the rear, the Optima was just a tad too big.
1stworks |
May 22 2013, 12:35 PM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
wndsnd |
May 22 2013, 12:55 PM
Kevin
Your Optima fits in the tray. Mine is like Jerry's and is a bit too long. They must have changed the base. I had the thought of mounting the controls and coil on DIN Rail. That way I could slide things out of the way if necessary. Anyone use mounting rails? |
Lo-Fi Version | Time is now: 18th May 2024 - 03:23 AM |
