Schnorr safety washers. Good source? |
Mike Bellis |
May 21 2013, 01:59 PM
Where can I get a bunch of Schnorr washers? PP has them for $1 each. EACH! seems like a rip off. $24 +shipping for washers is a bit much... (IMG:style_emoticons/default/dry.gif)
McMaster has non serated ones cheap, but not what I want. |
shuie |
May 21 2013, 02:16 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
You can get them in small bags from McMaster. They are listed a little goofy in the catalogue (Belleville Spring Washers), but they are there.
http://www.mcmaster.com/#safety-washers/=mum792 If you need them in really small quantities you can probably call the North America distributor for Schnorr and ask them for some samples. http://www.schnorr.com/safetywashers.html Phone: 734.677.2683 |
Jaymann |
May 21 2013, 02:27 PM
Member Group: Members Posts: 140 Joined: 18-August 09 From: Drexel hill pa Member No.: 10,692 Region Association: None |
I would call jonathan at GPR,he can prob hook u up.Jaymann
May 21 2013, 02:31 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rhodyguy |
May 21 2013, 03:09 PM
the part # for the belleville is #93501A030.
Java2570 |
May 21 2013, 03:11 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Eric @ PMB has them also.....
McMark |
May 21 2013, 05:13 PM
(IMG:style_emoticons/default/agree.gif) with the McMaster number. Or drop by and I'll hand you as many as you want.
two-strokejohn |
May 21 2013, 06:16 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
belmetric.com
Spoke |
May 21 2013, 07:14 PM
Eric @ PMB has them also..... (IMG:style_emoticons/default/agree.gif) Support a loyal 914 supplier. (IMG:style_emoticons/default/beerchug.gif) |
rick 918-S |
May 21 2013, 08:35 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm sure I've seen them at my local Ace Hardware.... (IMG:style_emoticons/default/idea.gif) I'm going to have to take another look. (IMG:style_emoticons/default/shades.gif)
draganc |
May 23 2013, 02:04 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I may have to remove and replace mine. I just ordered a pack from McMaster $10.25 for 100. Now which is the proper orientation for the washer? Concave (left) or Convex (right) (IMG:style_emoticons/default/confused24.gif) I would say it doesn't matter. |
McMark |
May 23 2013, 02:09 PM
It absolutely does matter. The ID should be towards the fastener head. If you want to know why, do a search because I've typed it before.
worn |
May 23 2013, 03:22 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
It absolutely does matter. The ID should be towards the fastener head. If you want to know why, do a search because I've typed it before. Looks like if you have a stationary part and a turning fastener head, that you would want the convex up and the concave side down. That would seat the washer. I say this because I didn't understand the abbreviation ID in this context. So this is a guess. |
rjames |
May 23 2013, 05:00 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE Now which is the proper orientation for the washer? A pic from 'Original Customs' taken from another thread: |
McMark |
May 23 2013, 06:12 PM
ID = inside diameter
The ID of the washer is roughly 8mm. If the hole in the cv joint is 8.5mm and you install the washer upside down then the washer will drop down into the hole slightly, thereby decreasing the spring tension of the washer. |
draganc |
May 23 2013, 07:32 PM
ID = inside diameter The ID of the washer is roughly 8mm. If the hole in the cv joint is 8.5mm and you install the washer upside down then the washer will drop down into the hole slightly, thereby decreasing the spring tension of the washer. Thanks for the explanation, which I fully agree and have installed my cv joints the same way plus safety wire. Not to start a pissing or "screwing" contest but don't you think that the OD area, when torqued, would "pull" the ID back out of the hole when flat? I tried looking for your previous post - unsuccessfully. I did however look up the schnorr.de page and they stated that the washer are reusable (I would/did change them, like you, for peace of mind and because they are low cost) and no reference about orientation. I have installed cv joints on two cars and I'm sure you have done plenty more, not challenging your experience just asking for better understanding. dc |
McMark |
May 23 2013, 10:11 PM
No, I love a good debate. (IMG:style_emoticons/default/smile.gif)
Theoretically I agree that the OD would 'pull it flat'. But the purpose of the washer is to apply force and increase the friction on the threads. Shortening the 'lever' of that spring reduces the force. Think about loosing a lug nut with a 12" wrench or a 24" wrench. |
draganc |
May 24 2013, 08:39 AM
No, I love a good debate. (IMG:style_emoticons/default/smile.gif) Theoretically I agree that the OD would 'pull it flat'. But the purpose of the washer is to apply force and increase the friction on the threads. Shortening the 'lever' of that spring reduces the force. Think about loosing a lug nut with a 12" wrench or a 24" wrench. Well, let the games begin: Theoretically you are right and I did/will follow "your" way. Even the fact that I believe it doesn't matter a lot - but that's just my opinion. Do you also increase the torque value by 10%, as per schnorr, for zinc plated screws? |
McMark |
May 24 2013, 10:50 AM
It probably doesn't matter a lot in practice. But I try to be the guy who puts in a little extra effort to do things a certain way. I often install washers with the rounded edges toward the paint to avoid scratches and put nuts on with the stampings out.
The torque values presented by Porsche were developed for Schnorr washers, so in a way, yes. (IMG:style_emoticons/default/wink.gif) |
Mike Bellis |
May 24 2013, 12:14 PM
It would appear that Mark is correct about mounting of the washer. Tha washers however can be stacked in both directions. When a single washer is used, it needs to be oriented as per Marks suggestion. If the washers are stacked, it will multiply the torque. See handbook.
Everything you ever wanted to know about Schnorr washers... Schnorr_Handbook.pdf ( 1.41mb ) Number of downloads: 327 |
Lo-Fi Version | Time is now: 18th May 2024 - 07:13 AM |
