QUOTE(McMark @ May 23 2013, 04:12 PM)
ID = inside diameter
The ID of the washer is roughly 8mm. If the hole in the cv joint is 8.5mm and you install the washer upside down then the washer will drop down into the hole slightly, thereby decreasing the spring tension of the washer.
Thanks for the explanation, which I fully agree and have installed my cv joints the same way plus safety wire.
Not to start a pissing or "screwing" contest but don't you think that the OD area, when torqued, would "pull" the ID back out of the hole when flat?
I tried looking for your previous post - unsuccessfully. I did however look up the schnorr.de page and they stated that the washer are reusable (I would/did change them, like you, for peace of mind and because they are low cost) and no reference about orientation.
I have installed cv joints on two cars and I'm sure you have done plenty more, not challenging your experience just asking for better understanding.
dc
