MR2 electric power steering rack, In a 914? |
Randal |
May 22 2013, 09:39 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Anyone ever try installing one in a 914? What I know about the racks is that the early versions are full time on, while the newer versions are only activated when you turn the wheel. Also know that the units draw a huge amount of amps, so a negative. Like 35A when turning the wheel All help appreciated. Just found a good write up: http://www.rx7club.com/fabrication-250/wri...version-847818/ |
Dr Evil |
May 22 2013, 09:43 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this?
Matt Romanowski |
May 22 2013, 10:09 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this? Power steering? (IMG:style_emoticons/default/idea.gif) |
Randal |
May 22 2013, 10:24 AM
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this? Running slicks in the front makes the car hard to turn. On a track day you'd hardly notice, but in an autox, where you are very busy, it's hard to be smooth and fast, given the input required. |
Randal |
May 22 2013, 10:26 AM
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this? Power steering? (IMG:style_emoticons/default/idea.gif) Right. Actually a Fabricator friend of mine just called and said he has used (on a Cobra) the electric assist out of a Prius, which is installed in line somewhere... you wouldn't need to change the rack. |
r_towle |
May 23 2013, 12:57 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this? Running slicks in the front makes the car hard to turn. On a track day you'd hardly notice, but in an autox, where you are very busy, it's hard to be smooth and fast, given the input required. Go to the gym (IMG:style_emoticons/default/smile.gif) Honestly, I would like to hear more about this. The older I get, the wider the car is becoming....which I suppose is the wrong way to do things...but money and youth did not add up for me (IMG:style_emoticons/default/smile.gif) |
Randal |
May 23 2013, 02:12 PM
I am in no way against innovation for the sake of innovation, but what would you hope to gain by doing this? Running slicks in the front makes the car hard to turn. On a track day you'd hardly notice, but in an autox, where you are very busy, it's hard to be smooth and fast, given the input required. Go to the gym (IMG:style_emoticons/default/smile.gif) Honestly, I would like to hear more about this. The older I get, the wider the car is becoming....which I suppose is the wrong way to do things...but money and youth did not add up for me (IMG:style_emoticons/default/smile.gif) Yea, your right about the gym. I figure if I do 40-50 pushups a night for two months before the Fall Enduro I'll be OK. Also bought a 330mm wheel, so that will help a little. |
Randal |
May 23 2013, 02:14 PM
There is a good write up here on the Pusus solution: http://www.autoshop101.com/forms/Hybrid17.pdf |
TurboWalt |
May 23 2013, 02:24 PM
Member Group: Members Posts: 157 Joined: 14-March 10 From: Chattanooga, TN Member No.: 11,463 Region Association: Northern California |
Checkout ezpowersteering, they offer a kit for 914. I have no idea of pricing.
Randal |
May 23 2013, 03:36 PM
TurboWalt |
May 24 2013, 08:27 AM
Randal,
Keep us posted on the price. I found a thread on the bird forum covering a 911 install. Sounds like a nice unit, but not cheap. http://forums.pelicanparts.com/porsche-911...r-steering.html Cheers, Walt |
Randal |
May 24 2013, 12:49 PM
Randal, Keep us posted on the price. I found a thread on the bird forum covering a 911 install. Sounds like a nice unit, but not cheap. http://forums.pelicanparts.com/porsche-911...r-steering.html Cheers, Walt Thanks for that bird board link. The Prius unit is reasonable, if you know where to go, so thinking I might explore this a bit more and report back. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:28 PM |
