FS: Rear "Race" Calipers, 911 rear calipers without spacers |
Eric_Shea |
May 23 2013, 05:50 PM
***Not for street use because there's no hand/emergency brake***
THAT SAID; this is part of our inventory reduction sale. We can currently make up about 3-4 sets of these rear 911 calipers without spacers (depending on how 911 rear sales are going and... they're going well so hurry). These would have the proper bias for a larger 911 48mm front piston. Here's what you would get: 15% larger pad (same as 911 or 914-6) 15% larger piston (same as 911 or 914-6) Bolt on upgrade for the rear to match the 48mm pistons in larger 911 front calipers w/o the spacers these calipers will bolt up to a stock 914 or 914-6 rear rotor (if you're five lug) "Perfect" bias match for the 48mm front pistons and not too large (E.G.: bolting an early 914 front on the rear). $99.00 per set plus shipping. |
carr914 |
May 23 2013, 07:39 PM
Racer from Birth Group: Members Posts: 118,784 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Eric, are these the ones we are talking about?
shuie |
May 23 2013, 07:48 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
This is a really good deal. I bought a set a while back and just put them on my car this week. It's a nice upgrade for a system w/non vented rotors that won't require a lot of messing around bending new hard lines. The inlet on the caliper lines up perfectly with the new stainless rear hard lines that Eric also sells.
Eric_Shea |
May 23 2013, 09:38 PM
Eric_Shea |
May 23 2013, 10:05 PM
Down to 1-2 sets now.
Steve |
May 24 2013, 08:02 AM
914 Guru Group: Members Posts: 5,596 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It's not that hard to convert to a 911 emergency brake, than these calipers would also be great for the street too!!
TravisNeff |
May 24 2013, 09:11 AM
I am in for 1 set
Eric_Shea |
May 24 2013, 02:12 PM
These are sold out.
Lo-Fi Version | Time is now: 25th May 2024 - 05:56 AM |
