***Not for street use because there's no hand/emergency brake***
THAT SAID; this is part of our inventory reduction sale. We can currently make up about 3-4 sets of these rear 911 calipers without spacers (depending on how 911 rear sales are going and... they're going well so hurry).
These would have the proper bias for a larger 911 48mm front piston. Here's what you would get:
15% larger pad (same as 911 or 914-6)
15% larger piston (same as 911 or 914-6)
Bolt on upgrade for the rear to match the 48mm pistons in larger 911 front calipers
w/o the spacers these calipers will bolt up to a stock 914 or 914-6 rear rotor (if you're five lug)
"Perfect" bias match for the 48mm front pistons and not too large (E.G.: bolting an early 914 front on the rear).
$99.00 per set plus shipping.
