65 alum 2.0 six, worth and if any problems |
ws91420 |
Nov 28 2004, 01:38 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
I have a line on a 2.0 six 65 alum block. What is it worth complete minus carbs and if any problems with this paticular type engine? Also they have a 84 924 motor. opinions welcomed
davep |
Nov 28 2004, 01:56 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Some people like the very early blocks because the aluminum is much stronger than the magnesium blocks that followed. Eventually, the factory went back to aluminum when the power output exceeded the capabilites of the mag blocks.
TimT |
Nov 28 2004, 02:01 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Early Alum case=good
probably has a c/w crank, the 2.0 heads are a little wanting, but they can be massaged. Dont have a clue of a fair price.. I did see an Alum case go on ebay for 350 awhile back. |
Eric_Shea |
Nov 28 2004, 02:11 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I sold a sand cast long block minus exhaust and carbs for $900 almost 10 years ago.
Very desirable short stroke starting block. You'll need to bush the layshaft and put squirters in if you plan on any high hp applications. Early sandcast aluminum blocks go for bigger bucks in the 911 circles (www.early911sregistry.org). If you "don't" plan on spending a bunch of bucks building a short stroke (layshaft, squirters, spigot bore for larger P&C's, P&C's and lots of headwork), it's probably best to spend that kind of dough on a nice 3.0 SC long block. Killer block though. If you can get it at the right price you can resell it on that other board. My $0.02 |
Jeroen |
Nov 28 2004, 02:21 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
I agree with Eric,
Some one looking for a "matching numbers" case or engine is most likely willing to pay a premium for this |
seanery |
Nov 28 2004, 02:57 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
or someone building a small bore race motor. (IMG:style_emoticons/default/driving.gif)
TimT |
Nov 28 2004, 03:31 PM
Also the early sand cast aluminum cases cant be upgraded to the late style pressure fed hydraulic tensioners easily. I believe you need to get new chain housing and possibly cam towers..
But the early chain tesnioners worked well in thousands of engines!! you could just get the collars that prevent tensioner collapse |
Lo-Fi Version | Time is now: 18th May 2024 - 11:33 AM |
