should I raise my front ride height ? Tire rub issue |
rfuerst911sc |
Jun 1 2013, 05:12 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I recently added 225/50 x 16 tires on 7 " rims on the front of my GT clone. Drives great and handles great but I'm getting tire rub when turning on the fender lips. These are metal GT flares and the fender lips are not rolled. I fear rolling the lips may damage the paint on the fenders. I'd be OK if it just damaged the paint to the lips but I do not want to risk damage to the fender. So I'm thinking of raising the front end, maybe 1 " higher ? I know it won't cure the problem 100 % but I think it would be a step in the right direction. Is there a " ballpark " rule on how much tire sidewall should be showing ? The car is definately raked towards the front, the car was aligned and corner balanced when I lived in Orlando. If I raised the front by turning equal amount of turns on the torsion bar adjusters would I be OK ? If it matters the front has stock torsion bars with a 19mm adjustable sway bar with stock strut inserts, the rear has Koni's with 140 lb. springs. I'm including a pic for opinions if the front is too low. Also what have others experienced with 225/50 in the fronts ? Thanks
Lo-Fi Version | Time is now: 1st June 2024 - 02:11 PM |
