well i dug the car out of a house full, as well as need suggestion |
scotty914 |
Nov 28 2004, 08:50 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i got motivated to start working on my car again, a year and a half later. but its amazing how much stuff piles up, esp when you house burns down and you have store everything you own. believe it or not it was running when i drove it in. now with a suby engine bolted to tranny, no engine bar. i got something done i can get to all sides and its on jack stands again (IMG:style_emoticons/default/smilie_pokal.gif) , it was sitting on its wheels.
this is how i found it (IMG:style_emoticons/default/wacko.gif) Attached image(s) |
scotty914 |
Nov 28 2004, 08:51 PM
this is now... full access
scotty914 |
Nov 28 2004, 08:58 PM
now for the suggestion part
the throttle body is 1 inch away from the truck springs, i know i have to remove them. but i need an air filter and maf sensor in there too. i was thinking of either cutting a flexable tube in to the trunk and putting the maf and air filter there, now i am thing about making a 45 degree wedge to turn the throttle body 45 degrees to the passenger side then another 45 to the maf and air fliter. i dont have enought room to put a full 90 on the throttle body and i would like to keep the turns more sweep and not that tight. Attached image(s) |
qa1142 |
Nov 28 2004, 09:01 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Little every day and I till turn heads again!
scotty914 |
Nov 28 2004, 09:03 PM
and as i stated before i plan on mounting the rad in front of the motor. i dont want to lose the front trunk, and it will fit. i will build a scoop undernieth to push air to the rad at speed.
also one last favor can somebody please go measure from the top of their tranny to the trunk floor so i can figure out motor height. tia pic is front of motor to fire wall Attached image(s) |
Brad Roberts |
Nov 28 2004, 10:58 PM
Scott,
I'm *pretty* sure that everyone os flipping the intake around on the heads so the throttlw body is facing forward. Glad you made some progress. It helps to do a little bit here and there to get re-motivated. B |
rick 918-S |
Nov 28 2004, 11:01 PM
Hey nice rack! -Celette Group: Members Posts: 20,441 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Keep going man! (IMG:style_emoticons/default/clap56.gif)
scotty914 |
Nov 28 2004, 11:54 PM
sorry brad, but the intake cant be turned around. the alt is top center, as it is now the intake manifold bows around the ac compressor ( some day ).
the flipped manifold you have heard of is the water pipes for use in a vanagon, since the motor is backwards heres the best pic i have to show the top of the motor Attached image(s) |
Brad Roberts |
Nov 28 2004, 11:57 PM
Hum.. I *thought* the guy's with the Turbo Scuby motors where flipping the intake..
OH WAIT.. that is the Boxster conversion guys flipping the 996 intake...LOL B |
redshift |
Nov 29 2004, 12:07 AM
Scott... don't put your radiator in front of the motor.
Ok, now, let's figure out where it can go... (IMG:style_emoticons/default/smile.gif) M |
scotty914 |
Nov 29 2004, 12:12 AM
well miles when i saw you responded i paniced
and one to more serious stuff ( till more smart (IMG:style_emoticons/default/bootyshake.gif) comments 3...2...1 ) where else should i put it oh miles' (IMG:style_emoticons/default/bootyshake.gif) |
redshift |
Nov 29 2004, 12:23 AM
Good Lord.. your ass looks like mikez's..
You have to get the air moving through that thing, and the air pressure up under that hole is going to go vertical.. have you seen a vented trunk, or bumper? You need to duct away about 2-3x the airflow you need.. as a rule of dumb. 914 rear ends want to fly at around 120-130mph... anyone know what the difference in the engine tin not being there is? M |
scotty914 |
Nov 29 2004, 12:34 AM
i am going to seal it up around the top and sides. and a scoop that will stick down 2 inches and will be about 5 by 30 when you look up from underneith
something likes this, dots are for spacing only x's are the rad <---- front | is the fire wall .....___ ....|....X ....|....X ....|....X __|....X floor pan height here __ ........./ |
Lo-Fi Version | Time is now: 4th May 2024 - 08:53 PM |
