Ignition Tumbler Removal (How) |
lsintampa |
Jun 1 2013, 02:03 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I searched and read a bunch of threads on removing the ignition key tumbler (lock itself, not the switch).
My tumbler is missing the chrome top piece and I have another tumbler to use and or use for parts, but I'm unable to remove the dumb tumbler. I saw many threads (and actually used the secrete release hole on the spare part)... But I've not seen one that has like this trap door on it - which I assume once removed will make it obvious how the tumbler is held in. Picture attached - if anyone knows how to get in there - (scratches are from me trying) without the obvious brute force method (or bigger hammer method)... that would be great help. Thanks, Len |
lsintampa |
Jun 1 2013, 03:16 PM
before someone tells me there is a release hole in the case - front of the tumbler in a channel - I know that's how I got the "spare" lock out, but this case doesn't have that hole...
and no it isn't filled with dirt.... I realized that both cases have that trap door, so I'm really not sure how (without any release holes) I'm getting that lock out of the case |
Jun 1 2013, 03:19 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bend open the punch downs
914Sixer |
Jun 2 2013, 08:05 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
IS that a 75-76 column ? If so it will have a black plastic cap, not chrome. You will need to drill a hole to release the lock assembly. The factory service manual covers where to drill. Perhaps some one can look it up and give you the details.
lsintampa |
Jun 2 2013, 09:41 AM
IS that a 75-76 column ? If so it will have a black plastic cap, not chrome. You will need to drill a hole to release the lock assembly. The factory service manual covers where to drill. Perhaps some one can look it up and give you the details. Yup, it is a 75.... forgot to mention that. So, I'm not going nuts then. So Porsche thought - hey let's not put this hole here any more, so in case someone need a new lock we can sell them the whole car instead!!! Yippee!! |
sean_v8_914 |
Jun 2 2013, 10:15 AM
push in the detent
Attached thumbnail(s) |
rgalla9146 |
Jun 2 2013, 10:37 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
push in the detent After you've drilled the hole ( in the right location ) there is a leaf spring inside. Push in on the spring while pulling the lock cylinder out with the key. The spring is barely visible in the above photo. It's in the shadow of the pointer. |
lsintampa |
Jun 2 2013, 12:18 PM
Yup,
I drilled it right the first time... all is well in teensville I used the broken "spare" to figure out where the hole needed to be drilled. 1/8" worked just fine. Thanks all! Len |
Lo-Fi Version | Time is now: 20th May 2024 - 09:07 PM |
