Foggy Temp Gauge, Only gauge the fogs! |
orthobiz |
Jun 1 2013, 09:12 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
My 1974 1.8 with center gauges has a perennially foggy temperature gauge. Sometimes the fogging is worse than other times but never goes away. I have read this thread:
http://www.914world.com/bbs2/index.php?sho...mp;#entry358798 and am reluctant to throw it in the oven. Aren't the lenses plastic? Anyway, it is currently sitting in a plastic bag with rice inside another bag with Damp Rid but no improvement yet. The thought of drilling a hole in the back to equalize the inside/outside moisture is interesting but I would worry about damaging something inside the gauge. The fogging has been there since I have owned the car and I'm wondering if it would ever clear up without removing the lens and cleaning it. I am not anxious to unroll the edge; I have done that on larger gauges like the speedometer before, but the small edge scares me a bit. Anyone else have experience in this? Thanks, Paul PS This is a clean gauge but a cell phone picture with a bright LED light is merciless! (IMG:http://www.914world.com/bbs2/uploads_offsite/farm8.staticflickr.com-7438-1370142754.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm4.staticflickr.com-7438-1370142755.2.jpg) |
speed metal army |
Jun 1 2013, 10:07 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
My voltmeter fogs...Hmmmm..
I also want a solution! (guilty of having tried nothing yet) |
Jun 2 2013, 06:36 AM
I would think that an oven at 100 degrees would do it.
Long and slow... Of, put it outside in the sunshine. Rich |
914Sixer |
Jun 2 2013, 07:58 AM
Take a small #1 flat blade screw driver and work your way around the ring and remove it. Lens is glass so be careful. Clean the lens and re-crimp the ring by gently pushing the edges back down with a larger blade screwdriver. You can tape the glass and the body and spray the the ring.
orthobiz |
Jun 2 2013, 11:36 AM
Take a small #1 flat blade screw driver and work your way around the ring and remove it. Lens is glass so be careful. Clean the lens and re-crimp the ring by gently pushing the edges back down with a larger blade screwdriver. You can tape the glass and the body and spray the the ring. I have done this years ago, I am too timid for fear of messing it up just before the June 24 concours. So if I wipe off the glass, won't it fog up again? But as a longer term question, the glass has moisture on it, I don't have any good reason why that should be, and especially in only one gauge. I sprayed some air into the light bulb hole and the lens improved temporarily but "bounced back" after I was done, back to its foggy state. Paul |
Lo-Fi Version | Time is now: 17th May 2024 - 01:11 PM |
