Back Pad Interior Light, Anyone find one that fits properly? |
saigon71 |
Jun 3 2013, 08:06 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Bought a repro a few years back from Ecklers Automotive. Tested it for fit today - not happening. Checked Pelican & Auto Atlanta. From the pics, they look to be the same reproduction light. I'm not concerned about originality, just want an operational dome light that actually fits.
Any advice on where to find a good fitting repro? Thanks. |
timothy_nd28 |
Jun 3 2013, 08:14 PM
balljoint |
Jun 3 2013, 09:04 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Cool. Lets see it installed.
My VW one holds fine in the backpad. Until it pops out again... |
dlkawashima |
Jun 3 2013, 10:08 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
That one comes in many sizes, but the smallest appears to be 12" long ... (IMG:style_emoticons/default/huh.gif)
http://www.visionxusa.com/LED-Shockwave/c1_251/index.html |
mrbubblehead |
Jun 3 2013, 11:28 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i believe it is a stock vw beetle light. try wolfsburg west.
Dave_Darling |
Jun 3 2013, 11:35 PM
Could it be that your back pad has been modified? The hole for the light enlarged?
--DD |
TravisNeff |
Jun 4 2013, 12:35 PM
The repro Hella's are a little too long and are tough to get into the backpad. I am pretty sure the repro lights are for a VW Beetle.
DBCooper |
Jun 4 2013, 05:15 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
The original lights were also VW beetle, so maybe the repros are different than the original?
saigon71 |
Jun 6 2013, 07:17 PM
The repro Hella's are a little too long and are tough to get into the backpad. (IMG:style_emoticons/default/agree.gif) Thanks for the info gents. (IMG:style_emoticons/default/beerchug.gif) It did seem a little bit long. After fiddling around with this for more time than I care to admit, I added some curl to the spring steel retaining tabs on the back side of the pad, effectively lengthening the distance between the edges of the tabs. The tabs still don't grab the light where they should, but it is held in place and looks pretty good: |
GeorgeRud |
Jun 6 2013, 08:24 PM
Has anyone tried switching to a LED bulb for that light? I always like the fact that they do not get hot like incandescent bulbs.
If someone has done it, what is the bulb you used? |
Lo-Fi Version | Time is now: 19th May 2024 - 09:41 PM |
