For those that purchased the GB tuna can. Solved, thanks for the help, Pics of installation were in the original GB thread (I should have gone there first, oops) |
dfelz |
Jun 3 2013, 08:38 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
The female bolt wouldnt fit through the bottom hole of the part with the dome mesh screen on it so i am assuming that it does not go back on with this set up, would like to know for sure though. And then does the other cylindrical part goes as i have it oriented???
Thanks for the help!! (IMG:style_emoticons/default/beerchug.gif) sorry for the smaller photo, accidentally hit small size when uploading to photobucket from iphone. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1370313535.1.jpg) |
ChrisFoley |
Jun 4 2013, 06:33 AM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Open up the hole in the center of the screen if you want to use it.
The sleeve goes as you show it. Use an adhesive sealant such as Motoseal or Yamabond to secure and seal the extension onto the pickup tube. It should go on about 80-120 thousandths for best results. |
dfelz |
Jun 5 2013, 12:44 PM
Open up the hole in the center of the screen if you want to use it. The sleeve goes as you show it. Use an adhesive sealant such as Motoseal or Yamabond to secure and seal the extension onto the pickup tube. It should go on about 80-120 thousandths for best results. Thanks for the reply Chris, but am a little confused since i dont know all the part names. For clarity, is the extension the the "goldish" part i refered to as the female bolt? and what is the pick up tube? Also, when you say go on about 80-120 thou, do you mean the sealant should go along the pickup tube in a 80-120 thou line from the edge?? Do you happen to have any pictures, even if its just of the pickup tube or something so i can get on the same page as you. thanks! |
914werke |
Jun 5 2013, 01:01 PM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
check out the original group buy thread I posted some pics that will clear up any confusion.
dfelz |
Jun 5 2013, 01:07 PM
jim_hoyland |
Jun 6 2013, 08:44 AM
Get that VIN ? Group: Members Posts: 9,275 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'm a little confused by the 80-120 thousandth part; (IMG:style_emoticons/default/confused24.gif)
ChrisFoley |
Jun 6 2013, 09:37 AM
That's about how far to slide the pickup extension onto the stock pickup tube. Any more and it will be too high, any less and it might come loose too easily. An adhesive sealant is required at that connection or the pickup will draw some air and oil pressure will be unreliable. |
jim_hoyland |
Jun 6 2013, 07:42 PM
Thanks, I assume that the overlap is really short ?
Lo-Fi Version | Time is now: 8th May 2024 - 04:25 PM |
