QUOTE(Racer Chris @ Jun 4 2013, 05:33 AM)
Open up the hole in the center of the screen if you want to use it.
The sleeve goes as you show it.
Use an adhesive sealant such as Motoseal or Yamabond to secure and seal the extension onto the pickup tube.
It should go on about 80-120 thousandths for best results.
Thanks for the reply Chris, but am a little confused since i dont know all the part names. For clarity, is the extension the the "goldish" part i refered to as the female bolt? and what is the pick up tube? Also, when you say go on about 80-120 thou, do you mean the sealant should go along the pickup tube in a 80-120 thou line from the edge?? Do you happen to have any pictures, even if its just of the pickup tube or something so i can get on the same page as you.
thanks!
