Hand brake ground connector on lever |
914itis |
Jun 4 2013, 08:51 PM
Does anyone have a picture of where the wire connector for the handbrake light attaches.
I can't seem to locate it with the seat bolted. |
Jun 4 2013, 09:00 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does anyone have a picture of where the wire connector for the handbrake light attaches. The switch is in a recess in the little cross-member that runs along in front of the seat. When the lever is down it presses on the switch knob opening the circuit. When the lever is up, the switch closes to ground. The switch is basically the same type as the ones in the door jambs for the interior light. (IMG:style_emoticons/default/shades.gif) |
914itis |
Jun 4 2013, 10:38 PM
Hm, I don't remember seeing a switch there, maybe mine is missing. Do i have to remove the seat or the handle to add a switch?
Thanks |
Jun 5 2013, 04:41 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Hm, I don't remember seeing a switch there, maybe mine is missing. Do i have to remove the seat or the handle to add a switch? Thanks Take out the seat and the carpet along the long. The switch fits in a small square hole in the crossmember, under the e-brake lever, right next to the long. just a single wire to the switch. |
PanelBilly |
Jun 5 2013, 10:20 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Pull the seat out. It's easy. Slide a long screw driver in between the seat rail and the seat frame. One of the sides has a spring plate retainer that keeps the seat from sliding off then just pull the seat coward and it slips off the frame. You'll find lots of goodies down there.
Cap'n Krusty |
Jun 5 2013, 11:53 AM
"Screwdriver"? You can pull the seat forward until it stops, push it back a touch, and put your finger under there, pushing up on the flat spring that stops the forward movement. Then pull the seat all the way out.
The Cap'n |
Lo-Fi Version | Time is now: 9th May 2024 - 06:14 AM |
