Hood pins., How many? |
Elliot Cannon |
Jun 7 2013, 04:08 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I have seen 914's with two and some with four hood pins in the front trunk. How many would be recommended for a fiberglass front trunk lid? Can I get away with just two?
Cheers, Elliot |
r_towle |
Jun 7 2013, 04:09 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
one, a really wide one.
McMark |
Jun 7 2013, 04:14 PM
I wouldn't on my car. At the very least, four pins gives you redundancy.
Elliot Cannon |
Jun 7 2013, 04:18 PM
Awright! You guys are going to talk me out of it. (IMG:style_emoticons/default/laugh.gif)
stugray |
Jun 7 2013, 04:58 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have been waiting to ask the exact same question.
I have a fiberglass hood where the PO did a POS job of installing the hood pins. I was going to fix the holes and put in four Aerocatch latches but I was waiting to decide where I wanted them before fixing the existing hood. I have seen both 2-pin or 4-pin at the races with 2-pin being the most common. Using the FG hood makes me tend towards 4-pin. Stu |
Elliot Cannon |
Jun 7 2013, 06:07 PM
I'm thinking maybe two of these but maybe not. I don't want anything silver looking what with all the "dzus" fasteners installed.
Attached image(s) |
r_towle |
Jun 7 2013, 06:13 PM
If you just use the stock latch, is there some evidence of that letting go from a fiberglass hood?
Think about all the fiberglass kit cars....no hood pins there. If you are keen on hardware, I would suggest you go back to your other passion and find some really cool looking airplane latches....and please document the install so we can steal your idea...and rag on you while yo do it. |
shoguneagle |
Jun 7 2013, 06:42 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
airplane latches are great but could be a little expensive and problem in installation. I like the racing pins with the appropriate metal backings underneath and on the exterior. I would use four when using the hinges; six if the lid is just placed on and secured by racing pins.
One thing that is a must is the modification of the fuel filler unit. I really like the hood fuel unit to be opened with a lid covering the filler cap and and aluminum filler cap/drain scupper/filler tube. Everything done right; really looks cool!!! Steve |
URY914 |
Jun 7 2013, 08:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
URY914 |
Jun 7 2013, 08:24 PM
The two in the rear of the hood are these slider type...
URY914 |
Jun 7 2013, 08:26 PM
Mugs914 |
Jun 7 2013, 08:54 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
Three seem to do a pretty good job of keeping the fiberglass out of yer face...
Headlight covers probably help too! (IMG:style_emoticons/default/shades.gif) Attached image(s) |
racerbvd |
Jun 7 2013, 10:04 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Elliot Cannon |
Jun 7 2013, 10:18 PM
The pins on that car look awfully heavy. (IMG:style_emoticons/default/happy11.gif) |
Elliot Cannon |
Jun 7 2013, 10:34 PM
If you just use the stock latch, is there some evidence of that letting go from a fiberglass hood? Think about all the fiberglass kit cars....no hood pins there. If you are keen on hardware, I would suggest you go back to your other passion and find some really cool looking airplane latches....and please document the install so we can steal your idea...and rag on you while yo do it. The FG hood is about 1/3 the weight of the stock hood and might flex just a bit more than the steel one. Having said all this about hood latches, I'm really loathe to drill any holes in my new hood (wasn't cheap). I think I'll use the stock latch with some sort of safety lanyard in case it decides it doesn't want to stay latched. |
Lo-Fi Version | Time is now: 20th May 2024 - 01:41 AM |
