gas tank nipple plug for carbed teeners, what have you done |
dfelz |
Jun 7 2013, 06:09 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
Since we only use one of the nipples on the tank, i wanted to see how others have plugged the one not in use, but not permanently on the tank (just in case)
I was thinking of getting a small circle of steel or alum and JB welding it inside the original aluminum nut that i would then screw on.... Whats your take?! |
Jun 7 2013, 06:23 PM
Hole saw to make the piece.
Two rubber washers In hindsight, a coin might fit also. The metal is just to push against the rubber washers. Bring the nut to the plumbing department...find a washer that is a bit bigger, cut with scissors. Done |
mrbubblehead |
Jun 7 2013, 06:27 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i screwed an AN fitting on with an AN cap.
Jun 7 2013, 06:32 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Whats your take?! When i had my carbed 2056, i simply plugged the return line in the engine compartment. Really no need to fiddle with the tank. (IMG:style_emoticons/default/popcorn[1].gif) |
FL000 |
Jun 7 2013, 07:15 PM
Member Group: Members Posts: 392 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I used a piece of 5/16 hose, a bolt with a smooth shank (cut off threads) and 2 hose clamps.
toolguy |
Jun 7 2013, 07:50 PM
punch out a circle from lead sheet
euro911 |
Jun 7 2013, 10:57 PM
unicyclerman |
Jun 8 2013, 12:13 AM
Newbie Group: Members Posts: 22 Joined: 26-April 10 From: Rancho cucamonga, Ca Member No.: 11,659 Region Association: Southern California |
I used an AN fitting capped off also. Wasn't too much either. not sure how common the tank fitting is but if you contact bonaco performance fittings in upland ca they can help you out. They custom make all their stuff And have the track fittings on hand.
unicyclerman |
Jun 8 2013, 12:19 AM
michael7810 |
Jun 8 2013, 06:04 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
rhodyguy |
Jun 8 2013, 07:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the shouldered bolt (so you're not clamping threads), short piece of proper hose and the 2 clamp method. use the stock fuel line clamps, not the slotted type. easy to undo if you ever need to. besides, it's cheap! you prob have the bolt and clamps you need in the coffee can full of used fasteners.
k |
ThePaintedMan |
Jun 8 2013, 08:14 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
the shouldered bolt (so you're not clamping threads), short piece of proper hose and the 2 clamp method. use the stock fuel line clamps, not the slotted type. easy to undo if you ever need to. besides, it's cheap! you prob have the bolt and clamps you need in the coffee can full of used fasteners. k ...And it gives you and easy, clean way of emptying the gas tank if you ever need to pull it. (IMG:style_emoticons/default/shades.gif) |
Krieger |
Jun 8 2013, 08:20 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/agree.gif) That is exactly what I did. I put about 16" of line on it so I could easily reach up and pull it out through the opening to drain. My thinking was if the car sat too long and the fuel got crappy I could get rid of the fuel.
dfelz |
Jun 8 2013, 05:04 PM
Thanks for the responses guys! All very good ideas. I do like the thought of being able to easily drain the tank if need be and having the plugged line would do that well. I will probably go that route. thanks for the pics too!
Michael, i too have the SS line from chris and was going to swap on the smaller connection tube. |
TheCabinetmaker |
Jun 8 2013, 07:13 PM
Hooking the supply line to the return nipple will lose your first defense against crude clogging your filter, trashing your pump, clogging your jets ,or worse, entering the combustion chamber.
michael7810 |
Jun 8 2013, 07:19 PM
I installed the smaller tube on the supply side and still use the original location with filter sock.
dfelz |
Jun 8 2013, 07:20 PM
Hooking the supply line to the return nipple will lose your first defense against crude clogging your filter, trashing your pump, clogging your jets ,or worse, entering the combustion chamber. I didnt quite explain it correctly then, i believe this is what Michael did too, but, what I am doing is taking the stem out of the original return line and moving just the stem over to the feed nipple, which has the filter stock on it that you speak of. So still using the supply location, as you correctly suggested, just swapping the stems for fitment purposes, since the original stem on the supply is larger and would have to reduce the fuel line via another fitting to fit onto the 8mm SS line correctly. Does that make sense? |
TheCabinetmaker |
Jun 8 2013, 07:53 PM
Absolutely. Thanks. Actually,very good idea. I've never changed a car to carbs, just the other way round.
michael7810 |
Jun 9 2013, 05:51 AM
Correct, I moved the small diameter stem to the original fuel supply fitting. If you're installing a new pump, make sure you remove the plastic cap from the fuel pump BEFORE installing the fuel hose. I didn't the the cap got jammed inside the rubber fuel hose. Fortunately for me I cut the fuel hose too short and had to replace it before before trying to start the car.
Harpo |
Jun 9 2013, 07:42 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Perfect timing,
I'm just about to hook up my new fuel pump to my new SS fuel lines from Chris. I was dreading having to struggle to get the larger gas tank nipple on to the smaller rubber fuel lines. Thanks David |
Lo-Fi Version | Time is now: 9th May 2024 - 05:29 AM |
