Anybody tried this?, Or similar replacement unit? |
Bob L. |
Jun 7 2013, 10:07 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
http://www.ebay.com/itm/Ignition-Lock-Cyli...9e8&vxp=mtr
Says it's "Hella" Does it really fit? Work well? |
Cap'n Krusty |
Jun 7 2013, 10:33 PM
May work for later cars, won't work for early cars. What year's yours?
The Cap'n |
TheCabinetmaker |
Jun 8 2013, 05:57 AM
Don't know if it's the same part # as mine, but it fits and works in a late model.
914Sixer |
Jun 8 2013, 07:17 AM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try Autohausaz.com. Look up the VW Beetle and the year. Same Hella lock $18.88. Why overpay??
Bob L. |
Jun 8 2013, 09:06 AM
Good responses, thanks. Mine's a '73. so I guess that is late?
I have the problem where turning the key in the ignition doesn't turn the electric switch far enough to connect the starter circuit. This might be a nice fix. |
7TPorsh |
Jun 10 2013, 12:26 PM
Is there a good source for a 1970 car?
Cap'n Krusty |
Jun 10 2013, 01:27 PM
Good responses, thanks. Mine's a '73. so I guess that is late? I have the problem where turning the key in the ignition doesn't turn the electric switch far enough to connect the starter circuit. This might be a nice fix. If those are the symptoms, that key and tumbler isn't gonna fix it. You need a new ignition switch. The Cap'n |
Bob L. |
Jun 10 2013, 02:25 PM
Good responses, thanks. Mine's a '73. so I guess that is late? I have the problem where turning the key in the ignition doesn't turn the electric switch far enough to connect the starter circuit. This might be a nice fix. If those are the symptoms, that key and tumbler isn't gonna fix it. You need a new ignition switch. The Cap'n I have a new one installed. I noticed the prong that engages the electric portion is twisted a little bit backward. Therefore it wont turn the electric switch far enough to make contact. I have a feeling that others out there have the same issue but are looking at the wrong part. Not all, but some. |
TheCabinetmaker |
Jun 10 2013, 07:25 PM
By late model, I mean 75/76.
Lo-Fi Version | Time is now: 9th May 2024 - 08:54 AM |
