Protective Cap for Oil Pressure Switch, Where do you get these? |
74914LE |
Jun 10 2013, 07:44 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Anyone know where to get the Protective Cap for the Oil Pressure Switch? It is #64 in the picture below.
Attached image(s) |
ThePaintedMan |
Jun 10 2013, 08:44 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Anyone know where to get the Protective Cap for the Oil Pressure Switch? It is #64 in the picture below. Pretty sure that those are NLA. But I found some "blind grommets" on Ebay awhile back to seal up the holes in my tin, and they work great. http://www.ebay.com/itm/10-x-PVC-Electrica...=item5d3ee9ea22 I can't remember who my original supplier was, but I got several in a couple different sizes. You'll have to measure the hole, as I don't remember what size it was. I think 45 mm? |
ThePaintedMan |
Jun 10 2013, 09:03 PM
If you find out the size, remind me, and I can send you one of the extras I have. I'm saving one for FourBlades, but I think I still have an extra.
JeffBowlsby |
Jun 10 2013, 09:42 PM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Bus Boys had them the last I checked.
timothy_nd28 |
Jun 10 2013, 09:46 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Bus Boys had them the last I checked. (IMG:style_emoticons/default/agree.gif) Just looked on the site. Here's the pn 021-119-957 |
ThePaintedMan |
Jun 11 2013, 07:31 AM
Sorry, I forgot that I use the dual sender on a grease hose extension, so the hole in the tin is really large without some kind of grommet to seal it. If you're using the stock sender, then the Bus Boys solution is probably the better way to go.
JeffBowlsby |
Jun 11 2013, 09:01 AM
AutoAtlanta has them too.
Cap'n Krusty |
Jun 11 2013, 09:05 AM
Sorry, I forgot that I use the dual sender on a grease hose extension, so the hole in the tin is really large without some kind of grommet to seal it. If you're using the stock sender, then the Bus Boys solution is probably the better way to go. The original formed grommet should work just fine for the remote mounted sender. The hole in the center is pretty small. Because the hole is not a simple circle cut in a flat surface, a plain grommet may not work at all ............. The Cap'n |
Lo-Fi Version | Time is now: 29th May 2024 - 06:36 PM |
