Heat Exchangers, Can 1.8s work on a 2.0 |
Mblizzard |
Jun 11 2013, 06:36 AM
I was just wondering if there was a difference in the 1.8 and 2.0 heat exchangers? I am looking at a 2.0 to swap out my ailing 1.8 and was wondering if the heat exchangers would work?
TheCabinetmaker |
Jun 11 2013, 06:45 AM
Yes. You will need to use muffler and hanger bracket from the 1.8 too. What year is your car? 74? use it. 75/76? backdate it.
Edit: If the are stock he's, you'll lose a couple of those 2.0 horses. Smaller diamater pipe. |
rhodyguy |
Jun 11 2013, 06:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
absolutely. all of 1.7/1.8 he components will swap over to the 2.0 as a package.
k |
DRPHIL914 |
Jun 11 2013, 07:32 AM
absolutely. all of 1.7/1.8 he components will swap over to the 2.0 as a package. k (IMG:style_emoticons/default/agree.gif) i have a 75 2.0 , ,when i purchased it i found the original restrictive system on there, leaking badly and replaced it with a new set of SS HE but at the time i did not know the difference in the 1.8 vs 2.0 - which is minimal and the SS's are the same diameter, and not restrictive like the 75-76's. Also put on a Triad and found this system to be a big improvement. Just order new gaskets and you will be good to go. phil |
Mblizzard |
Jun 11 2013, 08:23 AM
It is a 1975 1.8. It has SS heat exchangers on it now so I know they are not stock and should not be as restrictive as stock versions.
Gets me one step closer. |
TheCabinetmaker |
Jun 11 2013, 09:36 AM
Then its a direct swap.
Lo-Fi Version | Time is now: 9th May 2024 - 04:16 AM |
