First peak behind passenger seat, Rear window question |
Rhodes71/914 |
Nov 30 2004, 01:26 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Decided to pull the pass seat and see what it looked like under there. Not to bad actually, every time I read a rust post I got scared.
Here's a pic of the back window behind the pass side back pad. Is there supposed to be something holding the window in besides the sealing tape that is hangin down. Attached image(s) |
Rhodes71/914 |
Nov 30 2004, 01:30 AM
Also is that grey covering on the firewall stock, sound deadening maybe?
Here's a pic under the pass seat, looks good. Attached image(s) |
tesserra |
Nov 30 2004, 01:31 AM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
Yes there is.
After you fix and seal the window you will notice a huge difference in noise. George |
McMark |
Nov 30 2004, 01:35 AM
Gray pad is stock, "sealing tape" is not. Use 3M Window Weld to install. 3M parts number 08610. Available at most NAPA stores. Use a putty knife to remove the window, clean the area with lots of brake cleaner (or something else) to get the old gunk off. Clean the window up real nice. It's not worth resealing it if you don't clean the surfaces 100%.
scotty914 |
Nov 30 2004, 01:37 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
that tape you see is an attempt to stop the leak has nothing to do with holding the window in. the trim pieces and the buytle ( sp wrong ) hold it in.
it takes about an hour to do the window, just pick up the seal at flaps. there are some plastic spacers under the glass, if still factory, but dont need em. just be careful half the time the window falls out as you take out the trim. there is a tech article at PP on this. BTW pick up the seal that is on the out side, from the fire wall to engine lid, best time to do |
SpecialK |
Nov 30 2004, 01:41 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Yep, clean the channel and reseal the rear window. Also pull out the factory sound deadening pad (interior) and check underneath. I thought mine interior looked pretty solid until I pulled mine out..... (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/barf.gif)
Most say to take out the rubber pad, but if the window is sealed correctly I don't see the harm in leaving it in. |
SpecialK |
Nov 30 2004, 01:48 AM
After looking at your window pic again, it's obvious that water has been making its way into the passenger compartment. Definitely remove the rubber pad to see what, if any, damage has been done. And since you've got your seat out, pull back the carpet a little to get a look at the seatbelt attach points, mine were rusted out. And while you've got it this far apart, you might as well........ (IMG:style_emoticons/default/happy11.gif)
iamchappy |
Nov 30 2004, 07:37 AM
The black tape on the bottom of the window is stock, thats the way mine came from the factory.
boxstr |
Nov 30 2004, 09:20 AM
Since he didn't say anything about the window leaking or that it was loose. I wouldn't start removing it unless you need to.
And I to have found the black tape on 914s that I have torn apart were stock untouched. It is there mostly for cosmetic purpose. CCLINREARWINDOW |
rhodyguy |
Nov 30 2004, 09:26 AM
after you scratch the hell out the frame area removing the old hardened butyl seal your car may look like this.
hack Attached image(s) |
Rhodes71/914 |
Nov 30 2004, 11:32 AM
Yes the window is loose, was rattling quite a bit for the couple of weeks that I drove the car.
Guess I'll pull that pad and see what it looks like underneath. Just when I think I am moving forward (got the P&Cs back on the 2.0) I start tearing something else apart. |
Quebecer |
Nov 30 2004, 02:22 PM
SuperDan Group: Members Posts: 100 Joined: 13-May 04 From: Lachenaie, Qc, CANADA Member No.: 2,063 |
Welcome to the club ! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif)
Nov 30 2004, 03:09 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
also, do the "crunch test" on the floor behind the seat.
the floor is sealed with tar and if you have water standing there (because of a leaky rear window) it *will* rust under the tar. use your thumb and press firmly on the tar and listen for a crunch noise. the floor board has ribs, try in the lower parts of the ribs. if you hear crunchy-crunchy, you got rust! (IMG:style_emoticons/default/icon8.gif) Andy |
SpecialK |
Nov 30 2004, 05:48 PM
QUOTE(boxstr @ Nov 30 2004, 07:20 AM) Since he didn't say anything about the window leaking or that it was loose. I wouldn't start removing it unless you need to. And I to have found the black tape on 914s that I have torn apart were stock untouched. It is there mostly for cosmetic purpose. CCLINREARWINDOW He didn't have to say that the window was leaking, you can see the rusty water trail running down the rubber pad. If it ran down the outside of the pad, it's a sure bet that some went down behind also........rust BAAAAAD! (IMG:style_emoticons/default/ar15.gif) |
boxstr |
Nov 30 2004, 10:22 PM
Good eye Kevin.
CCLIN20/20 |
SpecialK |
Dec 1 2004, 01:36 AM
QUOTE(boxstr @ Nov 30 2004, 08:22 PM) Good eye Kevin. CCLIN20/20 I've just developed an eye for rust having seen so much of it on my "Rust-Free" '74.....( (IMG:style_emoticons/default/ar15.gif) ..PO's). Thought I was going to have an anxiety attack looking at the "reason I'm looking for a roller" thread (IMG:style_emoticons/default/ohmy.gif) ...but then again, misery loves company! |
Rhodes71/914 |
Dec 1 2004, 10:12 AM
Ok guys thanks for the support. Hopefully I will have some time tonight to pull off that pad, looks like it is glued on there pretty good. Of course I will post pics when I get in there.
mskala |
Dec 1 2004, 10:22 AM
QUOTE(iamchappy @ Nov 30 2004, 08:37 AM) The black tape on the bottom of the window is stock, thats the way mine came from the factory. It's true. |
Rhodes71/914 |
Dec 1 2004, 08:29 PM
Pulled off that backing crap, sure was a bitch, obviously it's been there since '71 Looked mostly good under there except this one spot. Passenger sid right next to the door.
Rhodes71/914 |
Dec 1 2004, 08:40 PM
Oh how nice right into the engine compartment, seems to be mostly the bottom corner. Will dig deeper when I pull the engine in a couple weeks. Like the wire nuts, not my doing. Most likely the same person that patched that hole with who knows what.
Lo-Fi Version | Time is now: 16th May 2024 - 01:56 AM |
