Tires for Auto X, Recommended tire size/type? |
green914 |
Jun 17 2013, 02:16 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I have the stock Fuchs 5.5 x 15 wheels, what would be a good choice for auto X? (IMG:style_emoticons/default/unsure.gif)
Woody |
Jun 17 2013, 09:06 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Do you plan on driving to events on the AX tires or are you going to swap once your there? Are these tires going to see much street use? Are you running in a class that requires non r-compound tires? Many different variables. What's your skill level?
Trekkor |
Jun 17 2013, 11:01 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Kuhmo 710
KT |
green914 |
Jun 18 2013, 12:23 AM
Do you plan on driving to events on the AX tires or are you going to swap once your there? Are these tires going to see much street use? Are you running in a class that requires non r-compound tires? Many different variables. What's your skill level? I plan on trailering it to and from events. I'm not sure what class my car would be in. I have not driven AX in 14 years, so that would probably put back to beginner's level. The car has 2.0 with carbs, and its suspension has been lowered, and stiffened up quite a bit. (IMG:style_emoticons/default/smile.gif) |
Woody |
Jun 18 2013, 06:04 AM
205/50R15s should fit those rims but you may have to pull the rear fenders just a bit. Hoosier A6s are pretty much the fastest thing out there right now in a DOT R compound. If your in a street tire class then I would seriously consider the BFG Rivals. If your on a budget then the Hankook RS3s are also a very good tire and I believe cheaper than the rest. The A6s are expensive, shouldn't be driven on the street, and require a bit more chassis set up to work to their full potential.
r_towle |
Jun 21 2013, 05:53 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hoosiers , and go into that class, it's more fun.
Lo-Fi Version | Time is now: 28th May 2024 - 01:44 AM |
