WTB: Seat Belt Mount "Nut" |
Kevins911 |
Jun 17 2013, 05:49 PM
Member Group: Members Posts: 52 Joined: 15-July 05 From: Kelowna, B.C. Member No.: 4,420 Region Association: Canada |
I need two of the seat belt mount nuts for the inner rockers, it's basically a nut welded to a 1"x4" peice steel, they are the ones in the center tunnel and inner rockers.
Alternatively, does anyone know what the size and thread pitch is? Could just make it up my self if I could find a supplier for the nuts. Thanks Kevin |
bulitt |
Jun 18 2013, 07:53 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
bdstone914 |
Jun 18 2013, 08:28 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I doubt they are u.s spec. No other fastener on the car is. I will measure one today. Bruce |
aaron72914 |
Jun 18 2013, 10:02 AM
Newbie Group: Members Posts: 16 Joined: 20-September 12 From: Republic, KS Member No.: 14,957 Region Association: None |
I may have some of these....I'll look tonight.
ThePaintedMan |
Jun 18 2013, 10:16 AM
I doubt they are u.s spec. No other fastener on the car is. I will measure one today. Bruce Bruce, Side note, but I think Bowlsby or someone has covered this in a thread before, which I don't have on hand at the moment. But I believe they said that seatbelt bolts had to be standardized in the U.S. so even if every other fastener is metric, the seatbelt hardware is not. Interested to see what you find though. |
Luke M |
Jun 18 2013, 01:38 PM
Senior Member Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I just made up a set for my brothers car.
The nut is a 7/16 '' x 20 thread. The factory bolts screw right in no problem. Get yourself some 1x4x3/16 steel drill a hole in the center and weld a 7/16x20 nut on it then weld it to the inside of the inner long. I don't have pics handy but I plan on taking some next time I'm over helping him. Hope this helps. (IMG:style_emoticons/default/beerchug.gif) |
Kevins911 |
Jun 18 2013, 07:21 PM
yep, thanks for the info, the seat belt hardware is all 7/16x20 confirmed with a tap and die. Would have never thought they were an SAE thread as the REPA bolts are graded as 8.8
Cheers Kevin |
Cap'n Krusty |
Jun 18 2013, 11:00 PM
I doubt they are u.s spec. No other fastener on the car is. I will measure one today. Bruce You're wrong. They're functionally 7/16" UNF. International standard. The Cap'n |
Lo-Fi Version | Time is now: 11th June 2024 - 01:51 PM |
