fuel pump for carbed 1.8, need to replace leaking fuel pump for carbed 75 1.8 |
dsphoto |
Jun 19 2013, 04:27 PM
Newbie Group: Members Posts: 21 Joined: 23-May 13 From: san dimas ca Member No.: 15,906 Region Association: None |
my fuel pump is leaking on my 75 1.8 and need to replace it so my garage doesn't explode one of these days when the water heater kicks on. The car was originally FI but the guy I bought it from had converted it to carbs if that makes any difference. Any suggestions on a good replacement fuel pump?
thanks! Dan |
mrbubblehead |
Jun 19 2013, 04:54 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i have been using a facet fuel pump for years. i have never seen one fail.
dsphoto |
Jun 19 2013, 05:02 PM
thanks, could you send a link to one? or what psi should i look for?
thanks again |
mrbubblehead |
Jun 19 2013, 05:06 PM
thanks, could you send a link to one? or what psi should i look for? thanks again sure... i was gonna but got sidetracked. you should also run a pressure regulator. and regulate it to 2.5-3.0 psi. the regulator not only meters the fuel but also smooths out the pulses from the facet. back in a minute with some links.... |
Lo-Fi Version | Time is now: 17th May 2024 - 08:22 PM |
