fuel pump for carbed 1.8, need to replace leaking fuel pump for carbed 75 1.8 |
dsphoto |
Jun 19 2013, 04:27 PM
Newbie Group: Members Posts: 21 Joined: 23-May 13 From: san dimas ca Member No.: 15,906 Region Association: None |
my fuel pump is leaking on my 75 1.8 and need to replace it so my garage doesn't explode one of these days when the water heater kicks on. The car was originally FI but the guy I bought it from had converted it to carbs if that makes any difference. Any suggestions on a good replacement fuel pump?
thanks! Dan |
mrbubblehead |
Jun 19 2013, 05:34 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
if you starting from scratch, i would recommend a good fuel filter also. i use a one micron canton canister filter. it has replaceable filters. any good filter will work just fine.
my set up goes like this. pump to regulator to filter (in the front trunk) then thru the tunnel to the back of the car then up behind the battery tray to the back of the carbs to a T-block that has a 1/8 npt port for a small pressure gauge then about 18 inches of hose out of the tee to each carb. i can take pictures if you need em. there are lots of tricks i have learned over the years to make your carbs bullet proof. i can share them with you if your interested. most tricks cost money but some are free. but each can be done a little at a time. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:02 PM |
