fuel pump for carbed 1.8, need to replace leaking fuel pump for carbed 75 1.8 |
dsphoto |
Jun 19 2013, 04:27 PM
Newbie Group: Members Posts: 21 Joined: 23-May 13 From: san dimas ca Member No.: 15,906 Region Association: None |
my fuel pump is leaking on my 75 1.8 and need to replace it so my garage doesn't explode one of these days when the water heater kicks on. The car was originally FI but the guy I bought it from had converted it to carbs if that makes any difference. Any suggestions on a good replacement fuel pump?
thanks! Dan |
dsphoto |
Jun 19 2013, 07:33 PM
ok so looking at pumps online trying to compare prices with other sellers. the one in the link doesn't have a model number but the picture on the page says 40105. This is 40105 from pegasus which doesn't state the same specs.
https://www.pegasusautoracing.com/productde....asp?RecID=8440 I'm a bit confused. So basically I just need one that can do about 3 psi and the regulator will control it to keep it at 2.5 to 3 psi? am i understanding this correctly? |
mrbubblehead |
Jun 19 2013, 07:51 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
ok so looking at pumps online trying to compare prices with other sellers. the one in the link doesn't have a model number but the picture on the page says 40105. This is 40105 from pegasus which doesn't state the same specs. https://www.pegasusautoracing.com/productde....asp?RecID=8440 I'm a bit confused. So basically I just need one that can do about 3 psi and the regulator will control it to keep it at 2.5 to 3 psi? am i understanding this correctly? the one from pegasus will be fine. you are looking for a low pressure pump when running carb. alot of the class 5 off road cars (type 4 powered) use the holley red pump. some manufacturers claim their pumps dont need regulators. cb performance and carter for instance. but carbs are pretty sensitive to pressure. so in order to cut down on trouble shooting i always run one. once your carbs are dialed in you will rarely have to mess with them. i havent touched mine in close to a year and my car is my daily driver. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:02 PM |
