fuel pump for carbed 1.8, need to replace leaking fuel pump for carbed 75 1.8 |
dsphoto |
Jun 19 2013, 04:27 PM
Newbie Group: Members Posts: 21 Joined: 23-May 13 From: san dimas ca Member No.: 15,906 Region Association: None |
my fuel pump is leaking on my 75 1.8 and need to replace it so my garage doesn't explode one of these days when the water heater kicks on. The car was originally FI but the guy I bought it from had converted it to carbs if that makes any difference. Any suggestions on a good replacement fuel pump?
thanks! Dan |
rhodyguy |
Jun 21 2013, 11:35 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you just have to take the stock harness end off as a cb pump has dif connectors. leave enough wire on the plug on the harness to repair the change, 2 spade ends and you're off to the races. i think the cb pump may fit in the stock pump bracket. no need for any isolators so it doesn't sound like a can of marbles being shaken. sounds like he's committed to the facet. good luck with your selection.
Lo-Fi Version | Time is now: 17th May 2024 - 08:09 PM |
