fuel pump for carbed 1.8, need to replace leaking fuel pump for carbed 75 1.8 |
dsphoto |
Jun 19 2013, 04:27 PM
Newbie Group: Members Posts: 21 Joined: 23-May 13 From: san dimas ca Member No.: 15,906 Region Association: None |
my fuel pump is leaking on my 75 1.8 and need to replace it so my garage doesn't explode one of these days when the water heater kicks on. The car was originally FI but the guy I bought it from had converted it to carbs if that makes any difference. Any suggestions on a good replacement fuel pump?
thanks! Dan |
dsphoto |
Jun 20 2013, 06:12 PM
So according to the site, I need the one piece supply line only in 9.5mm, correct?
http://www.tangerineracing.com/stainlessfuellines.htm |
ChrisFoley |
Jun 20 2013, 06:45 PM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
So according to the site, I need the one piece supply line only in 9.5mm, correct? http://www.tangerineracing.com/stainlessfuellines.htm Yes. |
ChrisFoley |
Jun 21 2013, 01:23 PM
So according to the site, I need the one piece supply line only in 9.5mm, correct? http://www.tangerineracing.com/stainlessfuellines.htm Yes. Dan, I started putting your order together and realized the 9.5mm supply line isn't the best choice to go in your '75 chassis. The plastic line currently installed is 8mm. The tank outlet fitting is 8mm. The pump fittings are screw-in so you can use whatever you like. The carbs probably have 8mm fittings on the inlet. I can switch everything to the 8mm size on the order if that seems right to you too. With the difference in price on the hose and clamps I can include a cap for the tank return fitting and still refund $3 to you. (IMG:style_emoticons/default/smile.gif) Chris |
Lo-Fi Version | Time is now: 21st May 2024 - 11:15 AM |
