ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
I recently confirmed that the trigger points were the cause of some running problems. I had a spare set so things are fine with my car, but I'm wondering if anyone rebuilds these. I can't see anything about them to provide a clue on why they aren't performing as they should.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
They act like a set of points. You can try cleaning the contacts.
ThinAir |
I tried cleaning the contacts, and using a small nail file to make sure the surface was clean. I also checked that the surfaces seemed parallel to ensure that they make good contact. The behavior I experienced was sputtering when I revved the engine.
McMark |
Another crude trick is to try and bend the spring arm to increase the tension against the distributor shaft. If the spring tension gets weak it can allow the contacts to bounce.
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
I wish they were rebuildable; the rubbing blocks that contact the dizzy shaft is what probably wears down. The references I have read say they last 100k miles. The other test is putting them on a scope and seeing that they have a good pattern. They truly are unobtanium and costs a bunch if you can find them. the strategy is to buy any and alll used dizzys and hope you get a decent set. I have paid $70 for a completely rebuilt dizzy on eBay and then I harvested the trigger points. the rest of the dizzy was junk.
Lo-Fi Version | Time is now: 3rd July 2025 - 10:55 AM |
