Spring on Rocker arms |
pcdarks |
Jun 25 2013, 09:08 AM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
There is a very lightweight spring assembly on the rocker arms that slips into the pushrod tube hole. It looks like it serves no purpose other that to provide a little pressure to hold the pushrod tubes in place. Is this necessary?
brant |
Jun 25 2013, 09:10 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
absolutely necessary
it holds the pushrod tubes into place as you said without it they will vibrate loose and you will have oil leaks absolutely necessary |
TheCabinetmaker |
Jun 25 2013, 09:11 AM
ABSOLUTELY!!!!!!!!!!!
Leave em out and be prepared to lose your oil. They hold the tubes in place. without them the tubes will, and I emphasize the "will", back out. |
pcdarks |
Jun 25 2013, 09:51 AM
Advice taken, It seems like they are pretty wimpy springs to hold the tubes in though.
Bob L. |
Jun 25 2013, 10:15 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
stugray |
Jun 25 2013, 10:26 AM
brant |
agreed
its not that tricky... but its an extremely common mistake to not get them correctly in place and then the oil leaks begin on your brand new motor. make sure you have them snapped correctly into place |
Elliot Cannon |
Jun 25 2013, 10:35 AM
I don't have them on mine. Haven't for 25,000 miles. No leaks. (IMG:style_emoticons/default/happy11.gif)
Jun 25 2013, 06:44 PM
Six-cylinder, Elliot?
BTW, it is not uncommon to leave the bent-down parts of the retainer sticking down inside the pushrod tubes. They will wear a groove in the pushrod if you do that, in addition to not holding the tube in place. The bent-down part of the wire needs to sit on the shoulder of the tube, so it presses it inward. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 02:42 PM |
