pcdarks
Jun 25 2013, 09:08 AM
There is a very lightweight spring assembly on the rocker arms that slips into the pushrod tube hole. It looks like it serves no purpose other that to provide a little pressure to hold the pushrod tubes in place. Is this necessary?
brant
Jun 25 2013, 09:10 AM
absolutely necessary
it holds the pushrod tubes into place as you said
without it they will vibrate loose and you will have oil leaks
TheCabinetmaker
Jun 25 2013, 09:11 AM
ABSOLUTELY!!!!!!!!!!!
Leave em out and be prepared to lose your oil.
They hold the tubes in place. without them the tubes will, and I emphasize the "will", back out.
pcdarks
Jun 25 2013, 09:51 AM
Advice taken, It seems like they are pretty wimpy springs to hold the tubes in though.
Bob L.
Jun 25 2013, 10:15 AM
QUOTE(pcdarks @ Jun 25 2013, 10:51 AM)
When installed correctly they "Snap" firmly into place. If yours don't feel secure then they probably aren't in right.
stugray
Jun 25 2013, 10:26 AM
brant
agreed
its not that tricky...
but its an extremely common mistake to not get them correctly in place
and then the oil leaks begin on your brand new motor.
make sure you have them snapped correctly into place
Elliot Cannon
Jun 25 2013, 10:35 AM
I don't have them on mine. Haven't for 25,000 miles. No leaks.
Dave_Darling
Jun 25 2013, 06:44 PM
Six-cylinder, Elliot?
BTW, it is not uncommon to leave the bent-down parts of the retainer sticking down inside the pushrod tubes. They will wear a groove in the pushrod if you do that, in addition to not holding the tube in place.
The bent-down part of the wire needs to sit on the shoulder of the tube, so it presses it inward.
--DD
