breather box vs. catch can, crankcase ventilation for my carbed /4 |
nebreitling |
Dec 1 2004, 01:32 PM
does it matter?
i was either going to do a standard 3-port bugpack type box, or tee everything off to a quart-sized catch can with mini filter. what are the pros/cons for each? i've heard that once oil leaves the heads to a breather box it should be considered dirty and not reused. in either case, i'd prefer not to modify the carbs for vaccuum fittings. |
Jake Raby |
Dec 1 2004, 01:38 PM
Call CSP and order their 1.8L unit. All the rest are Cjhinese toys. This one actually has enough volume to control a puke and drain it back to the case- and its baffled inside so you can run it to the carbs if you want..
nebreitling |
Dec 1 2004, 01:46 PM
thanks jake. how would you plumb this (with 6 ports)? each head high to either side, drain to oil filler low, and block off the unused ports?
nebreitling |
Dec 1 2004, 01:59 PM
looks cool
(IMG:http://www.csp-shop.de/shop/images/artikel/13816.jpg) "High polished breather box with six 1/2' tube fittings. 1-1/2-gal capacity. Baffled to stop oil slosh." clickhere |
Aaron Cox |
Dec 1 2004, 02:01 PM
58 euros (IMG:style_emoticons/default/wacko.gif)
nebreitling |
Dec 1 2004, 02:05 PM
not too bad at all (although the exhange rate SUCKS) -- considering that aircooled.net is selling their race-model breathers at $190.
Aaron Cox |
Dec 1 2004, 02:07 PM
nothing wrong with my 20 buck bugpack breather... cool aluymium mount i made... mounts it to the rear of the case...also holds fuel lines (IMG:style_emoticons/default/biggrin.gif)
Jake Raby |
Dec 1 2004, 02:09 PM
CSP has a US agent... 626 445 0108
His name is william, tell him I sent you. |
nebreitling |
Dec 1 2004, 02:11 PM
QUOTE(Aaron Cox @ Dec 1 2004, 12:07 PM) mounts it to the rear of the case... i thought you needed to elevate the box (excuse me, i mean "chinese toy"!) for proper drainage and avoidance of oil pooling in the lines |
Aaron Cox |
Dec 1 2004, 02:23 PM
its above the heads..... so it drains back into the heads...
JmuRiz |
Dec 1 2004, 10:57 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
QUOTE(nebreitling @ Dec 1 2004, 11:46 AM) thanks jake. how would you plumb this (with 6 ports)? each head high to either side, drain to oil filler low, and block off the unused ports? Cool, so you just need to use 3 of the ports? I just got a CB style one and was wondering if I needed to run the 4th port to a catch can/bottle or something. Just going to mount it to the firewall. Hell I could make a little baffle in mine if I wanted, easy enough to take apart, has a screen and foam in there now. Thanks for any tips on connections etc. BTW got it for $20 (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:42 PM |
