Broken Motor mount, Questions about motor mount for AX |
nolift914 |
Jun 28 2013, 12:53 PM
Autoxer Group: Members Posts: 183 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
During my second autox with the new 914 I broke the rubber motor mounts. I made a hard launch on my first run of the day when the mounts broke.
Looking for advice on an upgrade of the OEM mounts looking at the GPR aluminum mounts and the Jwest nylon ones. The motor is a Fat 2258cc type 4. |
brant |
Jun 28 2013, 12:57 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
During my second autox with the new 914 I broke the rubber motor mounts. I made a hard launch on my first run of the day when the mounts broke. Looking for advise on an upgrade of the OEM mounts looking at the GPR aluminum mounts and the Jwest nylon ones. The motor is a Fat 2258cc type 4. the stock mounts have a bolt sticking out top and bottom that bolt is actually 2 bolts bonded into the rubber its not a single bolt connected..... so when they fail it is often the rubber has torn or sheered a great solution is to find a good material (like delrin) and bore a hole all the way through the mount. make the upper and lower bolts of one piece of threaded stock. eliminate the ability for the two bolts to seperate. more vibration, but more secure than stock good for racing and not as brutal as solid metal |
Krieger |
Jun 28 2013, 01:53 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
How old were the mounts? Ive run my stock mounts for 8-9 ax seasons. No issues. Hard launches in first may end up costing you lots in other parts too.
Randal |
Jun 28 2013, 03:36 PM
Your story reminds me of the West Coast Ramble up in Medford a couple of year ago. I was running 911 sport mounts and one side broke. That was the reason I couldn't shift so Britain got me by a tenth in the autox. McMark spied the problem and borrowed a mount from another car and installed it so I could compete in the 5 lap Enduro, where I took the trophy... well actually there wasn't a trophy, just a kiss and a tickle. Thanks again Mark! But after that I went back to stock mounts and haven't had a problem since. And my autox launches are pretty violent, as it takes a bit to break loose 11" Avon (soft compound) slicks. |
Jun 28 2013, 06:38 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
During my second autox with the new 914 I broke the rubber motor mounts. I made a hard launch on my first run of the day when the mounts broke. Looking for advise on an upgrade of the OEM mounts looking at the GPR aluminum mounts and the Jwest nylon ones. The motor is a Fat 2258cc type 4. the stock mounts have a bolt sticking out top and bottom that bolt is actually 2 bolts bonded into the rubber its not a single bolt connected..... so when they fail it is often the rubber has torn or sheered a great solution is to find a good material (like delrin) and bore a hole all the way through the mount. make the upper and lower bolts of one piece of threaded stock. eliminate the ability for the two bolts to seperate. more vibration, but more secure than stock good for racing and not as brutal as solid metal Hockey pucks and a hole saw to make them the right size. Threaded rod all the way through. |
Matt Romanowski |
Jun 28 2013, 06:54 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Do they make 8.8 threaded rod? Using regular all thread is a recipe for disaster. I've seen motors remove themselves from 914s before...
brant |
Jun 28 2013, 07:03 PM
They do make quality bolts that you can cut the head off of.
Matt Romanowski |
Jun 28 2013, 08:30 PM
brant |
Jun 28 2013, 09:55 PM
Fair enough. Just a descriptor. We don't cut corners like that so all thread didn't cross my mind.
nolift914 |
Jun 29 2013, 05:13 AM
Thanks for the info, I decided on the the gpr Aluminum mounts.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.gprparts.com-10399-1372504593.1.jpg) |
Jun 29 2013, 08:53 PM
Do they make 8.8 threaded rod? Using regular all thread is a recipe for disaster. I've seen motors remove themselves from 914s before... Personally, I use real rubber mounts for that locatin. I feel that the motor needs to move in at least one location. The rest or solid mounts. If I was to use it, I only use grad 8 bolts, but thanks for jumping right in there. |
sgetsiv |
Jun 30 2013, 09:28 AM
Former 914 Owner :( Group: Members Posts: 159 Joined: 20-June 08 From: Portland, OR Member No.: 9,192 Region Association: Pacific Northwest |
You will get a lot of vibration with those. I had the JWest hard nylon mounts and switched back to factory to try and make the car a little bit nicer for street driving.
McMark |
Jun 30 2013, 11:18 AM
Make sure to check your transmission mounts as well and if stock, upgrade to 911 sport mounts. The 2436 Type IV in the shop has stock engine mounts and no problems when AXing or track days.
QUOTE Thanks again Mark! I was just doing what needed to be done. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/thumb3d.gif) |
Matt Romanowski |
Jun 30 2013, 06:24 PM
The Wevo mounts are worth the money over stock transmission mounts (IMHO).
sgetsiv |
Jun 30 2013, 11:36 PM
I switched to the Wevo black rubber (softer) transmission mounts when I switched out my engine mounts. Very smooth.
Lo-Fi Version | Time is now: 5th May 2024 - 05:07 PM |
