Trunk Hinge Repair Question |
76-914 |
Jun 28 2013, 01:02 PM
I posted this in my build thread but haven't received a reply. Any thoughts? See pic's at http://www.914world.com/bbs2/index.php?sho...01776&st=80 See post #91. (IMG:style_emoticons/default/welder.gif) TIA, kent
mikeyb33 |
Jun 28 2013, 01:20 PM
Slightly-usedbie Group: Members Posts: 84 Joined: 23-November 04 From: Santa Clara, CA Member No.: 3,168 |
I posted this in my build thread but haven't received a reply. Any thoughts? See pic's at http://www.914world.com/bbs2/index.php?sho...01776&st=80 See post #91. (IMG:style_emoticons/default/welder.gif) TIA, kent BTW / FYI, you can link directly to that post (number) - just substitute '91' in the URL you posted (which was for that page, 80 being top post on page). I.E: http://www.914world.com/bbs2/index.php?sho...01776&st=91 Alternatively, the post# is itself a link which can be copied/pasted: http://www.914world.com/bbs2/index.php?sho...p;#entry1886171 Hope this helps! (IMG:style_emoticons/default/type.gif) . |
Spoke |
The trunk pivot point is a bolt welded on the back of a bracket and the bracket welded onto the inner fender.
Remove the hinge and the pivot point will be obvious. This is a common break. |
pt_700 |
Jun 28 2013, 01:47 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
i had to do this several months ago. here's my dinky thread;
http://www.914world.com/bbs2/index.php?sho...=198204&hl= i ended up getting a used piece from someone here and having a muffler shop weld it in for me. it's holding up nicely several months later. doh! i see i forgot to post pics of that... i used the "much cursing" method of re-setting the torsion springs... it kinda appears you might be able to get away with adding some type of sleeve to locate the pivot bolt but, only if you're a cheap lazy bastid like me! |
76-914 |
Jun 28 2013, 05:25 PM
The trunk pivot point is a bolt welded on the back of a bracket and the bracket welded onto the inner fender. Remove the hinge and the pivot point will be obvious. This is a common break. Thx Jerry. I'll find one to replace it with. i had to do this several months ago. here's my dinky thread; http://www.914world.com/bbs2/index.php?sho...=198204&hl= i ended up getting a used piece from someone here and having a muffler shop weld it in for me. it's holding up nicely several months later. doh! i see i forgot to post pics of that... i used the "much cursing" method of re-setting the torsion springs... it kinda appears you might be able to get away with adding some type of sleeve to locate the pivot bolt but, only if you're a cheap lazy bastid like me! Well your "dinky thread" turned on a light in an otherwise dark room. Thx for the tips everyone. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:09 PM |
