QUOTE(Spoke @ Jun 28 2013, 12:20 PM)
The trunk pivot point is a bolt welded on the back of a bracket and the bracket welded onto the inner fender.
Remove the hinge and the pivot point will be obvious. This is a common break.
Thx Jerry. I'll find one to replace it with.
QUOTE(pt_700 @ Jun 28 2013, 12:47 PM)
i had to do this several months ago. here's my dinky thread;
http://www.914world.com/bbs2/index.php?sho...=198204&hl=i ended up getting a used piece from someone here and having a muffler shop weld it in for me. it's holding up nicely several months later.
doh! i see i forgot to post pics of that...
i used the "much cursing" method of re-setting the torsion springs...
it kinda appears you might be able to get away with adding some type of sleeve to locate the pivot bolt but, only if you're a cheap lazy bastid like me!
Well your "dinky thread" turned on a light in an otherwise dark room. Thx for the tips everyone.
