Euro Turn Signal wiring question, can't find the answer in the old thread |
sfrenck |
Jun 30 2013, 04:21 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
I want to have the amber lens light only be the turn signal and my Camp914 kit be my parking lights. I tried "tricking" things by hooking the Camp914 wiring up to the turn bucket 57 connector (disconnect the wire from 57 terminal, use the wire for the Camp914 light) and the turn bulb would not come on.
Read the following thread about disabling the parking light side of the 1157 bulb. Camp914 kit install Tried doing that by putting some electrical tape over that part of the bulb, but again that didn't work. Anyone know the secret? 1156 bulb maybe? My car has shaved side marker lights so those wires are available. ANSWER: 1157 bulb is correct, take the parking light wire off of the 57 terminal on the bucket and use it for the Camp914 light is also correct. Make sure the Camp 914 light has a good ground. I know that I tested this method 3x before posting the initial question, but I guess I needed to do it four times. (IMG:style_emoticons/default/headbang.gif) . Thx, S |
Mike Bellis |
Jun 30 2013, 07:30 PM
There are 3 wires on the bucket:
Ground Running Lights Turn signals Just disconnect the parking light wire and connect it to your new bulb. An 1156 lamp will not work. It will short both terminals together and cause the rear turn to light up every time the lights are on. It will also cause the rear parking lamp to flash. |
sfrenck |
Jun 30 2013, 08:17 PM
There are 3 wires on the bucket: Ground Running Lights Turn signals Just disconnect the parking light wire and connect it to your new bulb. An 1156 lamp will not work. It will short both terminals together and cause the rear turn to light up every time the lights are on. It will also cause the rear parking lamp to flash. I tried your method earlier (which makes total sense) - no turn signal if 57 is disconnected from the bucket. |
Mike Bellis |
Jun 30 2013, 09:22 PM
There are 3 wires on the bucket: Ground Running Lights Turn signals Just disconnect the parking light wire and connect it to your new bulb. An 1156 lamp will not work. It will short both terminals together and cause the rear turn to light up every time the lights are on. It will also cause the rear parking lamp to flash. I tried your method earlier (which makes total sense) - no turn signal if 57 is disconnected from the bucket. On the attached schematic, 58 is the wire you want, Grey/red and grey/black (right & left). If your turn signals stop working, you have another problem to fix. Both circuits are independent from each other. They only share a ground. You need further troubleshooting. disconnect all 3 wires from the bucket and connect a test lamp to them. They should work. If they are connected wrong OR you have a bad contact in the bucket, you will get the symptoms you describe. You also nee a Eruo 1157 lamp. They have an elongated contact point, unlike the American (Chinese) lamp available at your FLAPS. American style contacts (IMG:http://www.914world.com/bbs2/uploads_offsite/www.hotrodwires.com-10496-1372648964.1.jpg) European style contacts (IMG:http://www.914world.com/bbs2/uploads_offsite/www.ukledsdirect.com-10496-1372648965.2.jpg) |
montoya 73 2.0 |
Jun 30 2013, 09:40 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
try one of these threads:
Wanna make your own Euro Turn Signal Set Up, My backyard set up Euro Front Signal/City light conversion Euro turn signal installation project, Adding some bling with euro lenses and Camp914's kit Those are a few that I found while doing a search for the word euro. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:29 PM |
