bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,015 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
This is an engine that was destined for a Lemons car project. Need to sell. It needs oil pump, rocker arms, push rods , push rod tubes and other small parts installed. Can include other parts as needed.
It was a stock build meant for durability. Stock cam true 2.0L three bolt heads. Lightened flywheel. We plan to get the valve train put on and do a compression test. Do not know the compression ratio. Asking $1500 as is. I figure the the heads, valve job and assemble are well worth that. located in Riverside. Can deliver if needed in Socal area. Attached thumbnail(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 2nd July 2025 - 01:14 PM |
