This is an engine that was destined for a Lemons car project. Need to sell. It needs oil pump, rocker arms, push rods , push rod tubes and other small parts installed. Can include other parts as needed.
It was a stock build meant for durability. Stock cam true 2.0L three bolt heads. Lightened flywheel.
We plan to get the valve train put on and do a compression test. Do not know the compression ratio.
Asking $1500 as is. I figure the the heads, valve job and assemble are well worth that.
located in Riverside. Can deliver if needed in Socal area.
