replacement valve seats???, can i buy them? |
mattillac |
Dec 2 2004, 01:15 AM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
as posted in other threads i have a possible bad valve seat. i talked to my old man about the situation and he said it should be an "easy" fix. he said assuming the damage to the head wasn't too bad, he could machine the head and install an oversized valve seat. he works at a shop that makes alot of high tech stuff, so he has all the equipment. anyone know if an oversized valve seat is available, or even replacement valve seats available period. (IMG:style_emoticons/default/confused24.gif) thanks!
Dr Evil |
Dec 2 2004, 01:56 AM
Yes, they are available. Maybe Engine Builder Supply would have them. You can not just put them in, you need to set the correct crush. The crush is the difference between the hole in the head and the outer diameter of the new seat (roughly). Someone with more knowledge than me will likely bail us out now.
mattillac |
Dec 2 2004, 04:40 PM
mattillac |
Dec 2 2004, 09:38 PM
please, 914club engine pros, where can i get the valve seats. my old man said he can do the work if i can get him some new valve seats. please tell me where to get them:worship: i promise to post something helpful once i get this out of the way (IMG:style_emoticons/default/biggrin.gif)
thanks! (IMG:style_emoticons/default/rocking nana.gif) |
Dr Evil |
Dec 2 2004, 09:40 PM
Call a machine shop. THey either get them or make them. Also, look up Bug patch (sp). TIV head parts should not be hard to find.
Mueller |
Dec 2 2004, 10:32 PM
hmmm....i could be wrong here, but you "could" try to call the same shops that sell the replacement valves that you had been looking for (IMG:style_emoticons/default/smile.gif)
also, try Bugformance.... please bookmark the links I (and others) have provided to you (IMG:style_emoticons/default/wacko.gif) CB Performance Not too sure if the Haynes manual describes doing this procedure or not (you do have a manual correct???) also, here is a decent write up on doing this repair to a corvair engine head rebuilding |
mattillac |
Dec 2 2004, 10:55 PM
thanks guys! i'm going (IMG:style_emoticons/default/wacko.gif)
Mueller |
Dec 2 2004, 11:05 PM
when it comes to certain repairs such as heads, most people go to the "professionals".....I have a set of 1.8 heads that need a little work....i have a tough time paying someone else to do the job, but by the time I make the special tooling that is required it is just not worth it for me...besides, I'd hate to launch a motor due to me screwing something up and having a valve getting "intimate" with a piston.... (IMG:style_emoticons/default/icon8.gif)
brp914 |
Dec 2 2004, 11:07 PM
Unregistered |
My car dropped a seat and I had a new seat installed at Ollies in Santa Ana, CA. That was 15K mi ago. So far, so good.
mattillac |
Dec 3 2004, 11:02 PM
thanks again for the links everyone. but, after looking at a couple sites that sell the seats, i've not found 36mm seats, only 35.5 or 37.5 seats. whats up with that? my 75 2.0 has 36mm seats. is this just another case of me not looking hard enough (IMG:style_emoticons/default/wacko.gif)
i'm really starting to consider handing this job over to a pro and just coughing up the cash, but i'll have to wait till next year before i can afford it (IMG:style_emoticons/default/headbang.gif) but my old man says he can do it so i'll give him a chance first if he doesn't change his mind once he sees the heads. and i just can't say no to free stuff. (IMG:style_emoticons/default/clap56.gif) |
mattillac |
Dec 3 2004, 11:03 PM
specify: 36mm EXHAUST seats.
Dr Evil |
Dec 3 2004, 11:31 PM
um, is 36mm your valve outer/seat inner diameter? That would mean that you need to measure the outer diameter and go slightly up from there. Just a thought.
mattillac |
Dec 3 2004, 11:38 PM
good idea.
mattillac |
Dec 4 2004, 12:28 AM
so i guess 37.5mm valve seat.
Dr Evil |
Dec 4 2004, 01:05 AM
Now just figure out the crush tollerance. Call a VW machine shop, they should know.
Mark Henry |
Dec 4 2004, 10:58 AM
I wouldn't even try this without a proper head and seat machine (about $25K). Saving a couple of bucks isn't much of a savings if it wipes out your whole engine.
I charge $40 per stock seat (Canadian)...more if I have to custom make the seat. Also all seat material is not equal, most cheap seats are cast and total crap. How do you tell??? Take one and hammer it hard on the side...if it shatters it's cast, if it bends at least it’s steel. BTW these cheap seats are what most parts pushers sell. FYI using scrap heads my head guy and I ruined about a half dozen heads, before we found the proper way to install a seat in the T4 head. To much press and you will split the head...not enough and well, you know.... |
TheCabinetmaker |
Dec 4 2004, 11:47 AM
(IMG:style_emoticons/default/agree.gif) with Mark. Doing this yourself is a disastor that WILL happen. Stop being so cheap and fix them right. it'll be alot cheaper than replacing pistons, cylinders, and god knows what else later on.
mattillac |
Dec 4 2004, 12:42 PM
QUOTE(vsg914 @ Dec 4 2004, 09:47 AM) (IMG:style_emoticons/default/agree.gif) with Mark. Doing this yourself is a disastor that WILL happen. Stop being so cheap and fix them right. it'll be alot cheaper than replacing pistons, cylinders, and god knows what else later on. i'm not cheap i'm poor :finger2: and i have bills to pay. when i have the extra money it goes to my wife first (IMG:style_emoticons/default/wub.gif) , then the 914. i'd love to have a pro do the work, but it'll take me time to save up the money. i want to drive the car soon, but i dont want to do more damage either. aaaaaaarrrrrrrggggggghhhhh!!! (IMG:style_emoticons/default/headbang.gif) |
Mark Henry |
Dec 4 2004, 01:04 PM
I know what poor is like, but if it's one seat take it to Rimco, they'll most likely do one seat for around $30US.
Then get daddy-O to do the valve job. |
Jake Raby |
Dec 4 2004, 01:26 PM
Its all in experience with the type 4 head..
People wonder why the work is expensive- When they screw up a 500 buck head in 10 seconds they soon figure it out. Good heads are gonna be easier to buy soon- very soon. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:39 PM |
