First look into Transmission |
nine9three |
Jul 1 2013, 09:10 PM
Member Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
Have watched Mike's video a couple of times and wanted to know what you think of 1st gear dogteeth (aka "big bucks) and 1-3rd syncro rings. Calling Dr. Evil!
[attachmentid=396 303] Attached image(s) |
McMark |
Jul 1 2013, 10:24 PM
1st gear dog teeth are DEAD. The slider is probably okay, although the teeth are worn. All the other dogteeth I see look acceptable.
Disclamer: the pics are pretty small for seeing this stuff. (IMG:style_emoticons/default/wink.gif) |
Mike Bellis |
Jul 1 2013, 10:27 PM
Yep, these look wasted... (IMG:style_emoticons/default/sad.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-13946-1372734113.jpg) |
nine9three |
Jul 1 2013, 11:01 PM
So...consensus is 1st gear slider ok and 1st gear syncro hub (dogteeth) dead. Third gear syncro looks really, really bad??? Pitted? A better look at 1st gear dogteeth.
McMark |
Jul 1 2013, 11:41 PM
THAT'S a good pic. And THAT's a set of wasted dog teeth.
nine9three |
Jul 1 2013, 11:49 PM
McMark |
Jul 2 2013, 08:51 AM
Different metal harness. The slider has some wear, but new slider on new dogteeth can actually be harder to shift because of the ultra-sharp new points. A slight rounding of the teeth smooths engagement.
0396 |
Jul 2 2013, 04:57 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Like some have mentioned, first gear dogs and slider are toast. Since your already in there, you might as well change the pinion ,main shaft bearings , billet inter plate and also add Calif Motorsports bearing retainers too. I would do more , but that's the minimum for me. Good luck
nine9three |
Jul 2 2013, 05:22 PM
Like some have mentioned, first gear dogs and slider are toast. Since your already in there, you might as well change the pinion ,main shaft bearings , billet inter plate and also add Calif Motorsports bearing retainers too. I would do more , but that's the minimum for me. Good luck If you were doing a SBC or big six conversion, I might agree with some of your suggestions. This is a stock 2.0L four and the stock components have served it well in the past and a refreshing of syncros and a hub will keep it humming for years to come. The bearings look/perform like new. But this is me and I prefer the conservative approach. |
0396 |
Jul 2 2013, 05:29 PM
Like some have mentioned, first gear dogs and slider are toast. Since your already in there, you might as well change the pinion ,main shaft bearings , billet inter plate and also add Calif Motorsports bearing retainers too. I would do more , but that's the minimum for me. Good luck If you were doing a SBC or big six conversion, I might agree with some of your suggestions. This is a stock 2.0L four and the stock components have served it well in the past and a refreshing of syncros and a hub will keep it humming for years to come. The bearings look/perform like new. But this is me and I prefer the conservative approach. Your correct, everyone has a different view / budget. |
jimkelly |
Jul 2 2013, 06:02 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
brand new dogteeth
Cap'n Krusty |
Jul 2 2013, 07:52 PM
I would REALLY look at the bearings, especially the cages. Easy now, not easy later. You don't have to remove the shafts, just pull off the gears and washers and put the ol' inspect to 'em.
The Cap'n |
Matt Romanowski |
Jul 2 2013, 09:21 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
When I bought bearings in the spring, pinion shaft bearings were very hard to find. I think I found the last new one in the US at the time.
Lo-Fi Version | Time is now: 13th May 2024 - 06:47 PM |
