CHT tin hole grommet, Available/ replacement?? |
Porschef |
Jul 2 2013, 06:47 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Noticed today that where I once thought was a seal/ grommet for the wire for the CHT lead, there ain't. I figure a lot of cooling air heading for the fins on #3 is takin' a detour right out the hole..
Any source/ replacements available??? Thanks. |
ThePaintedMan |
Jul 2 2013, 08:21 PM
Noticed today that where I once thought was a seal/ grommet for the wire for the CHT lead, there ain't. I figure a lot of cooling air heading for the fins on #3 is takin' a detour right out the hole.. Any source/ replacements available??? Thanks. Search for "Blind hole grommet" on Ebay. I ordered a bunch from the UK awhile back in various sizes. You can cut a slit in it as needed. Also works well for those who installed a dual pole oil pressure sender on a grease hose, which leaves a massive hole in the tin. |
Porschef |
Jul 3 2013, 04:21 AM
Thanks George, I'll give that a shot
saigon71 |
Jul 3 2013, 05:37 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
If you are in a hurry, take a trip to your local Ace hardware store.
I was able to make one out of three different size grommets glued together - it turned out pretty good. |
JamesM |
Jul 3 2013, 08:26 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
021 119 569 A
When in doubt, search out our VW brothers http://www.busdepot.com/021119569a While you are there pick up 021119957 as well (IMG:style_emoticons/default/smile.gif) it leaves an even bigger hole in the tin if you dont have it |
Lo-Fi Version | Time is now: 15th May 2024 - 04:47 AM |
