Sealants-the last 1 I ever use, I see much ?? about which one |
jwalters |
Dec 2 2004, 05:18 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/smilie_pokal.gif) I have seen a tremendous amount of tech questions related to sealants. I have come across one, ( actually pointed out to me by a very, very old vw mechanic) quite a number of years ago.
It is a TOYOTA "seal packing" compound--P/N-00295-01281 It comes in a metal squeeze tube of 3.5 oz. each tube costs about 15 bucks. But this is what is so neat about it: It plainly states on the tube " transaxle sealant" --but personally I can tell you that I have used this stuff on all manner except fuel related components. It is orange in color, and only slightly hardens when applied and torqued. Best of all, it only requires a skim coat ( just enough to see it) because it wets out the entire mating surface perfectly. One tube has lasted me through 4 v-8 engine rebuilds, and it has paid for itself many times over. Regular fluids, incl gasoline does not affect this stuff, and because it does not through harden, as parts heat and cool, the sealant stays intact. That is just one thing I have picked up from being a gearhead and making good friends.... (IMG:style_emoticons/default/aktion035.gif) |
jwalters |
Dec 2 2004, 05:54 PM
(IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) and here is another good one for fuel components--it is called PRC-8802
This is also an aviation grade sealant, two part---will absolutely positively seal any, ANY fuel related component for LIFE!!! Goes on like hot cheese, dries to a rubber consistency, can be removed with elbow grease and a lexan sharpened scraper..... (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) |
rick 918-S |
Dec 2 2004, 07:49 PM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Go to the Yamaha Dealer, Buy a tube of Yamabond! (IMG:style_emoticons/default/clap56.gif) I sealed a prussurized oil leak from the outside of the block on the 928. Got me through the summer. It's aluminum colored.
Lo-Fi Version | Time is now: 16th May 2024 - 01:45 AM |
